Old Jun 3, 2008 | 07:15 PM
  #131
rcostin's Avatar
Default RE: DVD in motion patch for NR261UM
ORIGINAL: Mitsu_Fizzle
To get hings off the HDD (30.94 stylee), will I need this....
http://www.compusa.com/applications/...9952&CatId=448
or this..
http://www.compusa.com/applications/...9310&CatId=470
Your input is appreciated.
Btw, if both will work... which will be the safest/easiest one?
You will need the second one to unlock the disk, using a PC. That's the only tool that can do the job.
Also, after unlocking, you may use the first one, considering that you may want to reattach back the PC's hdd and boot windows. Is much easier to work on USB with the unlocked disk.
Old Jun 3, 2008 | 07:20 PM
  #132
brian360's Avatar
http://www.compusa.com/applications/...&CatId=448
(edit: i take that back, it appears it does indeed have a 44-pin connector on it) A USB adapter will NOT work for unlocking the drive. However, once the drive is unlocked, you may use a USB adapter (personally I have this one) to easily copy files off of it.
This adapter is REQUIRED to unlock the drive with the bootable linux CD (xbhdm). Simply disconnect all the drives from your system, except your CD-ROM drive (which should be on the 2nd IDE channel on your motherboard anyway), and connect the MMCS hard drive with this adapter. PAY ATTENTION to the orientation when connecting it to the MMCS' HDD! Reversing it will damage the hard drive and/or your motherboard. Some adapters have a "key" to prevent you connecting it backwards, some do not, so use caution. Also, its VERY easy to bend the pins on the hard drive, so be extremely careful when removing the connector.
Personally, I have both, so I use both. The 2nd one lets me unlock the drive, then the first one lets me access it on any PC I want very easily via USB until I put the drive back in the MMCS. Its also proved to be a handy tool for many other things (such as cloning a disk in a PC if you have friends/family that need PC support often...)
Costin beat me to the reply His was much shorter and easier to read ... haha
Old Jun 4, 2008 | 12:42 AM
  #133
lunaillij's Avatar
Thanks for the great work! I just did this update on my 08 lancer and my fiancees 07 Outlander and IT WORKED GREAT!!! We both have the BLD-NR-261UM 1.09/2068 Navi version. I've been waitin a while for a great solution. I wanna thank you for the info.
Old Jun 4, 2008 | 02:10 AM
  #134
rcostin's Avatar
ORIGINAL: brian360
This is because I sent the answer from my E90 phone, so I had to be veeeery short
Old Jun 5, 2008 | 07:47 PM
  #135
goofygrin's Avatar
OK I pulled my drive with the 00.30.94 version.
The ALLDATA.KWI and LOADING.KWI are here -> http://www.mpghead.com/00.30.94.zip
Please don't download this if you don't need to since it'll eat up my bandwith
And please post the patch CD for us!
Thanks!
Old Jun 5, 2008 | 07:59 PM
  #136
brian360's Avatar
Thanks!!
Old Jun 5, 2008 | 08:37 PM
  #137
POMPOUS_JACKASS's Avatar
Thanks a lot! I am eagerly awaiting the file to be patched now =)
Old Jun 5, 2008 | 09:33 PM
  #138
MisterStrike's Avatar
Sweet!
Old Jun 6, 2008 | 01:46 AM
  #139
m20racer's Avatar
it took me abit to fidure out how to unpack the files but once i did and installed it in the navi (08lancer gts us) it works!![sm=icon_rock.gif]
Old Jun 6, 2008 | 05:47 PM
  #140
sa7an's Avatar
does this hack let you have video from the aux feed up while driving?
if so is there any way to make the aux feed only show video and keep the audio from say sirius playing, possibly with controls over the audio source while doing it?
reason i ask is this for the evo http://www.hksusa.com/info/?id=3474
