ORIGINAL: Mitsu_Fizzle
To get hings off the HDD (30.94 stylee), will I need this....
http://www.compusa.com/applications/...9952&CatId=448
or this..
http://www.compusa.com/applications/...9310&CatId=470
Your input is appreciated.
Btw, if both will work... which will be the safest/easiest one?
or this..
Also, after unlocking, you may use the first one, considering that you may want to reattach back the PC's hdd and boot windows. Is much easier to work on USB with the unlocked disk.
http://www.compusa.com/applications/...&CatId=448
This adapter is REQUIRED to unlock the drive with the bootable linux CD (xbhdm). Simply disconnect all the drives from your system, except your CD-ROM drive (which should be on the 2nd IDE channel on your motherboard anyway), and connect the MMCS hard drive with this adapter. PAY ATTENTION to the orientation when connecting it to the MMCS' HDD! Reversing it will damage the hard drive and/or your motherboard. Some adapters have a "key" to prevent you connecting it backwards, some do not, so use caution. Also, its VERY easy to bend the pins on the hard drive, so be extremely careful when removing the connector.
Costin beat me to the reply
His was much shorter and easier to read ... haha
Thanks for the great work! I just did this update on my 08 lancer and my fiancees 07 Outlander and IT WORKED GREAT!!! We both have the BLD-NR-261UM 1.09/2068 Navi version. I've been waitin a while for a great solution. I wanna thank you for the info.
ORIGINAL: brian360
OK I pulled my drive with the 00.30.94 version.
The ALLDATA.KWI and LOADING.KWI are here -> http://www.mpghead.com/00.30.94.zip
Please don't download this if you don't need to since it'll eat up my bandwith
And please post the patch CD for us!
Thanks!
Thanks!
does this hack let you have video from the aux feed up while driving?
if so is there any way to make the aux feed only show video and keep the audio from say sirius playing, possibly with controls over the audio source while doing it?
reason i ask is this for the evo http://www.hksusa.com/info/?id=3474
