Old May 26, 2009 | 01:33 PM
  #731
steph1693's Avatar
Don't seem to work, i put the burned cd into the mmcs and nothing, it says check disc...
Old May 26, 2009 | 03:23 PM
  #732
steph1693's Avatar
Nr261um, 1.09 00.30.94.
Old May 26, 2009 | 05:47 PM
  #733
Alpha7's Avatar
* Any Changes made could destroy your MMCS Unit, do it at your own risk, backup any changes you make. *
- All I downgraded my unit and got it working - a temporary fix if anyone doesn't want to wait. -
So I downgraded my unit from v30.99 to 30.94, I have seen no lost in functionality and right now the DVD in motion hack works. All I did was copy over the LOADKING.KWI and ALLDATA.KWI from here http://www.deltainfo.ro/manuals/mitsu/outlander/ and replaced my LOADKING.KWI and ALLDATA.KWI with those two files. Download the CD-Patch below that and reinstall the HDD and run the update. ** Backup the original files before doing anything.
-- A little fun if anyone wants to mess with the screen files.
Note: When I did the downgrade I lost all my custom screen files, so if you are think you want to downgrade the unit do that first if planning to edit any screen files
Once you get the hard drive unlocked and hooked up to the computer you will notice it has 6 additional partitions ( I highlighted the MMCSs ones) J - O are all for the Unit for me :Note You probably will not have the exact drive letters that I had it assigned.
First thing I want to say is do NOT replace this file with anything. I did and my unit did NOT start up. I practically broke the entire thing until I replace the file with the original.
I always thought that the Bluetooth screen that came up when we got a call was utterly retarded ( I thought my unit broke the first time I got a call and flipped out ) So I figured I would replace that first. Here is the file Listed on the Drive
Here is it replaced
And I went online found an image, resized it and renamed the original to a _bak file and replace it with my custom image.
The Results
The other thing I did (but somehow my screenshot didn't save) was replace the Mitsu intro with one on the hard drive, like I've said before there are 4 additional files you can easily replace, or make or find your own.
-- Another thing I did was go through and replace my Blue background with a Green one.
now I did this in multiple location but here is one screenie
I was unable to find the "Blue Border" for all of the buttons because its embedded somewhere but I think the green on blue looks pretty decent.
Old May 27, 2009 | 01:29 PM
  #734
bumpin_records's Avatar
well guys and gals my question is as i know a lot asked on here is there a patch for the 2009 models?
Old May 27, 2009 | 08:16 PM
  #735
rip14's Avatar
If you have version 30.99 (which you probably do) then no. Some people have been able to downgrade to .94 and make it work.
Old May 28, 2009 | 12:31 AM
  #736
izzyevo's Avatar
Default Downgrading question
Does it require hacking the hard drive and connecting it to a computer to replace the .99 file to .94?
Old May 28, 2009 | 07:02 AM
  #737
steph1693's Avatar
Originally Posted by ninamarie
Should have worked for you then.
Are you sure you followed everything perfectly?
Burned the correct file as an ISO and turned radio off but car on...
at first, i made an error... the disc had the iso image itself. Burn it again with nero but not express, nero burning rom and then i had the 2 files on the cd. Try it and did not work. try it on a cd-rw then on a cd-r and nothing. the cd loads but nothing happend, no disc error.
Old May 31, 2009 | 02:45 AM
  #738
WiValdiBB's Avatar
Smile
I have MMCS version 31.06 i bootloader 1.09
I couldn't patched DVD in Motion with files from:
and burned few CD's by NERO i MagicISO, always only "Checking Disc" and nothing more happened
Maybe I did something wrong but above I wrote exactly how I did success
I found files also at:
http://www.whatifoundonline.com/
I don't know maybe both files sources are OK, but I changed ISO burner soft to ImgBurn v2.4.4.0 (1,993 KB) downloaded here: http://www.imgburn.com/index.php?act=download
When you open ISO file then ignore "Invalid or corrupt authenticity information" and burn as is but with speed x1
Log:
I 00:21:36 Write Mode: CD
I 00:21:36 Write Type: SAO
I 00:21:36 Write Speed: 1x
I 00:21:36 Lock Volume: Yes
I 00:21:36 Test Mode: No
I 00:21:36 OPC: No
I 00:21:36 BURN-Proof: Enabled
RUN ENGINE, switch MMCS to NAVI
press OPEN,
insert CD and after "Checking Disc" when MMCS ask to update
press YES and wait few minuts untill it finish and reboot by self.
After restart when MMCS ask to update again press NO. Take CD out and enjoy your DVD when you drive
Don't forget: RESPECT to OTAKU
or better Donate to keep his good work: http://www.takingthingsapart.org/ind...d=31&Itemid=37
Old May 31, 2009 | 10:24 PM
  #739
djalpine's Avatar
Log:
I 00:21:36 OPC: No
press OPEN,
So after reading this forum and knowing what is happening you have v31.06 and used the file and it works? I do not think you have v31.06....I think all the others would have it working by now if that is the case
Can someone confirm that this does or does not work? It does not work for me but.....who knows....
Old Jun 1, 2009 | 10:37 AM
  #740
greeneagle's Avatar
Default loading view software
Hi Otaku,
Could you give us an estimate of when you expect to be able to have the license for the loading view software available for purchase?
Thanks and Best Regards,
