Old Jun 2, 2009 | 06:52 AM
  #741
steph1693's Avatar
Originally Posted by WiValdiBB
I have MMCS version 31.06 i bootloader 1.09
I couldn't patched DVD in Motion with files from:
http://www.deltainfo.ro/manuals/mitsu/outlander/
and burned few CD's by NERO i MagicISO, always only "Checking Disc" and nothing more happened
Maybe I did something wrong but above I wrote exactly how I did success
I found files also at:
http://www.whatifoundonline.com/
I don't know maybe both files sources are OK, but I changed ISO burner soft to ImgBurn v2.4.4.0 (1,993 KB) downloaded here: http://www.imgburn.com/index.php?act=download
When you open ISO file then ignore "Invalid or corrupt authenticity information" and burn as is but with speed x1
Log:
I 00:21:36 Write Mode: CD
I 00:21:36 Write Type: SAO
I 00:21:36 Write Speed: 1x
I 00:21:36 Lock Volume: Yes
I 00:21:36 Test Mode: No
I 00:21:36 OPC: No
I 00:21:36 BURN-Proof: Enabled
RUN ENGINE, switch MMCS to NAVI
press OPEN,
insert CD and after "Checking Disc" when MMCS ask to update
press YES and wait few minuts untill it finish and reboot by self.
After restart when MMCS ask to update again press NO. Take CD out and enjoy your DVD when you drive
Don't forget: RESPECT to OTAKU
or better Donate to keep his good work: http://www.takingthingsapart.org/ind...d=31&Itemid=37
Thanks to you, it worked!!! i just can't explain why but it worked. i just burned the iso file with image burn and put the cd in the mmcs on navi mode and then it ask for updating, press yes, reboot and work.
Old Jun 2, 2009 | 11:58 AM
  #742
garywatkins1981's Avatar
Default version 00.30.97
i have version 00.30.97 i have not seen a link to the update for it can someone please post it
Old Jun 2, 2009 | 11:16 PM
  #743
well it be posted in this forum when it is? and do u know about how long it will take to come out? thanks for the help
Old Jun 2, 2009 | 11:38 PM
  #744
biris's Avatar
what about 00.40.11 ?
Old Jun 4, 2009 | 12:36 AM
  #745
biris's Avatar
Default 00.40.11
i can't wait for the new patch
Old Jun 4, 2009 | 03:57 AM
  #746
WiValdiBB's Avatar
Default DVD in Motion
Originally Posted by djalpine
So after reading this forum and knowing what is happening you have v31.06 and used the file and it works? I do not think you have v31.06....
Why? I have 31.06, boot 1.09. I can check version of MMCS! Do you need MMCS photo from me?
Can someone confirm that this does or does not work? It does not work for me but.....who knows....
Don't give up djalpine, just try again, like me, believe me, it works Greets from Poland
Old Jun 4, 2009 | 04:04 AM
  #747
WiValdiBB's Avatar
Nice, I had the same, a lot of problems with unlocking DVD, it just didn't worked. So I decide to write exactly step by step how to did it. I'm happy to help anybody, if any Greets from Poland
Old Jun 8, 2009 | 12:39 PM
  #748
any word on version 30.97 yet
Old Jun 11, 2009 | 10:25 PM
  #749
djalpine's Avatar
Why? I have 31.06, boot 1.09. I can check version of MMCS! Do you need MMCS photo from me?Don't give up djalpine, just try again, like me, believe me, it works Greets from Poland
I do not doubt you. I see you are from Poland. Not sure how those Units are programmed. Weird. If yours worked I am happy for you. We have 30.97/30.99 versions unless we update our maps then who knows what it will go to. Maybe we should not update our maps Apparently only the nav units in Poland work with the fix. I did actually try what you said. I never saw the ability to ignore errors. Can you tell me where that option is in the burning program?
Old Jun 12, 2009 | 12:00 AM
  #750
WiValdiBB's Avatar
When you load iso file to IMGBURN, then is information: "Invalid or corrupt authenticity information"
Just ignore them and start burning.
Did you try IMGBURN ?
My MMCS is european wersion, exactly:
SW Version E
Map Version 2006-1
CDDB Version 0663-0000
Loader BLD-NR-261EM 1.09
Application: 00.31.06
Navi Sub Microcomputer 00.30.00 089004
Audio Microcomputer 09.29.02 002902
Map Data M110 AEU_07_2007013
Monitor: 00.27.00
CAN BOX: 000120
