Electrical fault!!
So i can go out to my mitsubishi outlander 57 plate on a morning try opening the car with the unlock button on the key fob and the wing mirrors dont open and none of the doors will unlock. So ive to put the key in the drivers door to open the car manually. Put the key in the ignition and the car automatically tries to fire on the second turn off the key but doesnt actually start up. Then on other occassions can do the exact same procedure with the key fob. But the mirrors will open all the doors will unlock put the key in the ignition and the car will start absolutely fine! Just to mention checked all ground straps,batteries only a couple of month old. Its had a new ignition switch fitted. Any help will be massively apreciated. Thank you.
I would first connect any obd2 tool and read all errors, interestingly if there are any CAN bus related ones.
