EPB reset brake open/close caliber
Old May 3, 2020 | 01:56 PM
Martin Laporte's Avatar
Is this procedure works with 2019 Outlanders ?
Old Jun 12, 2020 | 09:12 AM
JGoll1010's Avatar
Does the car have to be jacked up to perform this manually procedure?
Old Aug 11, 2022 | 06:29 AM
DaveoSimplson's Avatar
If anyone needs MUT-3 SE (No Car Programming) setup on a laptop to complete EPB servicing let me know...
Old Aug 25, 2022 | 09:42 PM
Akjose's Avatar
yes please. Pm sent.
Old Aug 29, 2022 | 07:11 AM
Homer1959's Avatar
I've seen that some other brand can be retracted by feeding 12volts from a powerpack through the caliper terminals . That activates the actuator and retract the actuator . Cant see why that would not work on a Outlander
Old Aug 29, 2022 | 04:12 PM
DibbyDibbyDJ's Avatar
There is a risk to overheating the motors, which is the second most common failure of these calipers. The first being when wannabe mechanics try forcing the pistons back.
The signal from the EPB ECU is rapidly pulsed to stop overheating. i have heard of 9v batteries being used, but have no evidence of this
Old Aug 29, 2022 | 04:22 PM
Homer1959's Avatar
Well when the time come ill take my chance , knowing what you just said Ill use many run and stop to be gentle with the actuator motor ... Ill let you know if all goes up in smoke lol but I am not too worry :-)
Old Sep 13, 2022 | 03:28 PM
Akjose's Avatar
Originally Posted by mikestah
Hi all,
You need to enter the vehicle into maintenance mode.
It can be done with the MUT - III scan tool, or manually by utilising the park brake switch.
Refer to below to use the park brake switch to enter maintenance mode
anyone have luck with this procedure. There is a good video on YouTube but I can’t duplicate the procedure.
i can get the EPb lockout message but then I can’t get the EPB to disengage before disco the battery.
Last time I changed pads the outlander beeped excessively at me until I got it reset at the dealer. Was free. Just don’t know how often they will do this for free.
Old Oct 23, 2022 | 04:16 PM
Psychobillybear's Avatar
Default I need this please
I am letting you know I need this
Old Oct 23, 2022 | 06:18 PM
Akjose's Avatar
I just did this the other day by using a 9v battery to reverse the EPb piston.
1. Disconnect negative side of battery.
2. Disconnect the plug on top of the caliper for the EPB system.
3. remove caliper and old pads.
4. Use a 9v battery with alligator clips (test leads) to reverse the caliper direction.
4a. Connect the leads and see if the piston move outwards, if it does, reverse polarity.
4b. Connect leads u til it moves some, then squeeze it in with clamp. I used a ratcheting quick grip clamp.
5. Insert to pads into positon.
6. Check caliper fitment over pads.
7. Repeat steps 4-5 as needed until it is the right depth.
8. Reconnect battery.
9. Turn car on (not start engine).
10. Apply EPB emergency brake (pull up on switch). You will hear the EPB whine for longer than it normally does.
11. Release EPB.
NO TROUBLE CODES, NO ERADIC BEEPING, NO WARNINGS OF PARK BRAKE DISABLED.
supposedly there is a point where you can wind the piston too far and it locks in or bottoms out. I didn’t get to that point and not sure what happens if you do.
