EPB reset brake open/close caliber
Old Oct 23, 2022 | 06:20 PM
  #21
Akjose's Avatar
Originally Posted by JGoll1010
Does the car have to be jacked up to perform this manually procedure?
I did one side at a time using a 9v to wind the piston back.
how else would you change the brakes if it’s not jacked up?
Old Oct 23, 2022 | 06:22 PM
  #22
Akjose's Avatar
Originally Posted by Homer1959
Well when the time come ill take my chance , knowing what you just said Ill use many run and stop to be gentle with the actuator motor ... Ill let you know if all goes up in smoke lol but I am not too worry :-)
confirmed. This works. 9v at least. If you have a power pack I have seen that work as well.
Old Oct 23, 2022 | 09:38 PM
  #23
Psychobillybear's Avatar
Default Mut 3 se
Originally Posted by DaveoSimplson
If anyone needs MUT-3 SE (No Car Programming) setup on a laptop to complete EPB servicing let me know...
hey I need this please
Old Oct 24, 2022 | 07:42 AM
  #24
Homer1959's Avatar
Thanks for the confirmation Akjose :-)
Old Jan 10, 2023 | 12:18 PM
  #25
shwallywally's Avatar
Default Parking service brake maintenance mode
I can’t get it out of parking brake maintenance mode. Did anyone else have issues with that? I have searched all over the internet for ways to do it and I have done 3 or 4 ways. Last way I did it was disconnected the battery and reconnected after about 5 minutes and everything stayed the same
Old Aug 24, 2023 | 10:35 AM
  #26
Assich's Avatar
Make sure you connected the epb's plugs back in. Try spinning both sides back to the point of piston turning again and reconnect etc. You can unbolt the epb unit from the back of the caliper and manually unlock if it has jammed. There are instructions elsewhere for that.
Old Oct 12, 2023 | 12:48 PM
  #27
reevesjo's Avatar
And I am asking. Please...reevesjo@embarqmail.com
I don't know how to contact him personally.
Old Apr 30, 2024 | 08:17 PM
  #28
nick.hamham's Avatar
I need need this please!
Old Jun 15, 2024 | 05:33 PM
  #29
TAHOE420's Avatar
Exclamation I need this
Please set me up !
Old Sep 1, 2025 | 03:54 PM
  #30
Kylepro's Avatar
Yes please send it to me.
kyleprovancher@gmail.com
