ETACS options customization
Old Jul 11, 2015 | 08:08 AM
  #1191
Vadimus's Avatar
Originally Posted by otcmx
I hope this doesn't happen to anyone else. But if it does, it's not the end of the world.
Positive thinking is the key!
Old Jul 12, 2015 | 09:10 AM
  #1192
Detlev's Avatar
is it possible to set the mmcs so that het video/on will work?
Old Jul 13, 2015 | 03:26 PM
  #1193
Vadimus's Avatar
Try to say it in different words.
Old Jul 20, 2015 | 09:00 PM
  #1194
Blankskater08's Avatar
Ok guys, I made an account strictly for this thread. Haha
I read all 120 pages, as well as a few other threads. This has come with good and bad. Watching it from the start with Lexia/PP2000 through all the Diagbox updates.
This does leave me a bit confused.
I should have the programmer on the way. I will be focusing on most US models of Lancers.
I take it ETACS Decoder is greater than Diagbox now?
What all is needed for install these days?
Is Windows 8 supported?
Are the original settings saved in case you need to flash back to stock?
(How would you keep track of that one multiple cars?)
Did anyone ever figure out if the sunroof option worked on the Lancer?
What else should I know?
I feel like once the software is running and I am in the car I will be good, it's just getting there that seems tricky.
Not trying to repeat questions, I just think I over researched some. Not a bad thing though, learned a lot from the mistakes and what others have discovered.
Thank you!
Old Jul 20, 2015 | 10:53 PM
  #1195
Guyfromhe's Avatar
ETACS decoder has been greater than diagbox since it was conceived.
Diagbox took an hour to install and used like 8 gigs of disk space.
I think ED will work on almost any hardware it seems pretty lightweight. I don't know if it supports Win 8 but I bet it does. Vad will eventually chime in with the answer.
It logs everything and there is a special string at the top of the screen you can copy and paste that contains all the settings of the car your working on and you can keep that anywhere you please.
I haven't installed the latest ver but the last one I used didn't have anything special to keep track of multiple cars.
If anyone knows about the sunroof Vad would.. I know it works on the Outlanders.
ETACS decoder is super easy to use. You just connect make sure it reads your coding string and VIN and then go through the options and set what you'd like and then encode and write... It tells you when to power cycle your car, etc.
One thing to note you _might_ get some warnings on your dash when you write your ETACS, this scared the crap out of me the first time but it goes away after a "reboot".
Also copy the coding string at the top as soon as it's read from your car. If anything goes wrong you can always paste it and return to the way it was before. This saved me once.
Old Jul 20, 2015 | 11:24 PM
  #1196
Definitely good to know. Sounds like ED is the way to go these days.
I know in the past you would have like 4 different programs to make this work. Haha
Now I registered on the ED page too.
Do you have to pay to download? I saw something about hits on the server, what is that about?
Just trying to get everything setup so I don't jump into it blind.
I appreciate the help.
Old Jul 21, 2015 | 08:29 AM
  #1197
Guyfromhe's Avatar
I had issues with that due to lack of wifi in my garage (I don't know if it was just me or if it's fixed yet, I switched back to a legacy ver)
I think they allow a certain number of writes per day and then after that you need to pay a small fee as people were using it commercially I think it's like 4 or 5 which should do any single user but you can get a pack of "hits" for a few bucks.
Old Jul 21, 2015 | 09:14 AM
  #1198
Ok, so say I change 3 things and then write it. That's one hit, and you are allowed X number per day before you must buy more.
Old Jul 21, 2015 | 09:25 AM
  #1199
Guyfromhe's Avatar
Yes. You pick all your settings and when you hit encode it sends your options to the server to generate the new config string and that is a hit.
Old Jul 21, 2015 | 09:36 AM
  #1200
Awesome, that's not bad then unless you are doing a lot of testing or a lot of cars.
Now.....to get wifi in the garage. Lol
