ETACS options customization
Old Jan 6, 2013 | 12:33 PM
  #621
Gen-8's Avatar
So vadimus when can we get the software lol.. Waiting patiently to customise my JDM lol
Old Jan 7, 2013 | 03:18 AM
  #622
otromen02's Avatar
Same here! Need to enable Autoleveling Headlamp, reappear back my MMC welcome logo and change back the ODO to KM instead of Miles
Old Jan 7, 2013 | 05:10 PM
  #623
spekil's Avatar
Originally Posted by Vadimus
Once autoreset is disabled in ETACS, change avg mode from A to M (using Info button on the dash, don't forget to engage parking break to make settings menu visible!).
With autoreset disabled, it won't switch from M to A anymore.
I'm using diagbox 6.22 but couldnt find autoreset in the vehicle options. What I found was avg fuel economy and current fuel economy. I tried changing one of them and both to missing but fuel economy disappears in the dash display.
I wonder what I miss...
Old Jan 8, 2013 | 04:27 AM
  #624
galant2003's Avatar
Change "Trip Computer Autoreset Return at IG on" from "available" to "not available". Reset the other changes, they are not necessary ...
Old Jan 8, 2013 | 07:40 AM
  #625
spekil's Avatar
Sounds good! I'll try it later.. thank you
Update:
It freaking worked! Thanks!
Now, I hope somebody can chime in on how to wire the oem parking assist.
Old Jan 18, 2013 | 05:34 PM
  #626
galant2003's Avatar
Somebody tested Diagbox 6.35 with the clone interface and firmware 4.2.4?
Old Jan 20, 2013 | 12:48 PM
  #627
allezzov's Avatar
Default Daytime Running Lights for 2012 Outlander (US)
I just wanted to report that my attempt to activate DRL on my 2012 Outlander failed.
I swapped the headlight relay (with heatsink) from my wife's 2010 Outlander with DRLs and placed it into my 2012. I went into DiagBox and tried all the options under the "Type of Day Running Lights" option. The low beams failed to energize in a low light condition similar to the 2010. I tried all the options with the emergency handle in the down position and in Park and Drive.
Has anyone tried doing this? Neither vehicle has HID lamps.
Old Jan 21, 2013 | 12:09 PM
  #628
galant2003's Avatar
Check the options in your wifes Outlander with DiagBox. You can print all options and compare. Maybee there is a hardware difference?
Old Jan 22, 2013 | 07:45 AM
  #629
allezzov's Avatar
Default reply to Galant2003-
The first thing I did prior to any updating was to print out all the factory settings for both vehicles. I did compare the value of the DRLs and changed mine to match hers - would not work. Another thing I noticed - I changed my Driving Lights to turn on independently of my low beams. Her vehicle (dealer installed Driving Lights) could not be changed to turn on independently via DiagBox as mine. There must be some changes to the logic within the two years.
Old Jan 22, 2013 | 02:56 PM
  #630
spekil's Avatar
Help:
I programmed an 08 evo mr for tpms diabling, auto doorlocks, fog lights. Then after, the car dont have forward and reverse. It only says on the dash a blinking R and drive.
Any help?
Additionally, his fast key is not working properly.
Could there be any conflict when I turned off the tpms and why wouldnt the car go?
