FAST key goes AWOL
FAST key goes AWOL
My FAST key took on a mind of its own the other day. For some reason, the security system did not recognize my key as the key I had previously started the car with. None of the keyless systems would work nor would the lock/unlock button work on the remote. When opening the car manually, the car alarm went off. The car would not turn over when I tried just the valet key. After calling my dealer, I learned that I should try starting it by using the back of the key fob to turn the valet key. The lesson learned is that if you ever have a problem you should call your dealer for help. The good news is my other key works. When I have time, I'll get my crazy fast key reprogrammed and find out what the problem was. I just wanted to put this up in case anyone else encounters this problem. I'll keep everyone posted when I get my key fixed.
the key should probably be replaced. Some early keys were susceptible to issues when in too close proximity to things like cell phones, etc.
newer keys are redesigned.
of course, i have no idea your year, cuz you didnt say.
