Fault code p2148 after battery charging problem
Old Oct 17, 2023 | 01:25 PM
Richardhollis's Avatar
Default Fault code p2148 after battery charging problem
Hi everyone, I had a drain on the car (outlander 2010 2.2 diesel) which flattened the battery. I connected up my battery charger and foolishly opened the drivers door which set off the alarm. As the battery was completely drained it seemed to cause some sort of electrical spike which blew the battery charger. Now when I've tried the car the engine runs very rough with no power. Engine management light is on and fault codes show p2148 and pending p0202. I suspect I might of damaged the ecu. Is there any way of checking or is there a fuse or relay I can check first? Thanks in advance. Richard
Old Oct 18, 2023 | 09:03 AM
Outlaander's Avatar
Do you have a new, FULLY CHARGED battery in the vehicle right now and are still getting the same codes? If you are, disconnect the negative terminal's cable, fully charge the battery without the vehicle's negative cable attached to the batter, then re-connect the negative cable and keep the charger attached to the battery, then try to start the vehicle. It may be necessary to attach an OBD diagnostic tool to the vehicle so that the codes can be cleared.
Good luck.
Old Oct 19, 2023 | 03:55 AM
Good luck.
yes I did that initially. But I'll try that again and see what happens.
yardbird
Mar 25, 2024 11:21 PM
jald3rd
Jul 22, 2015 08:48 PM
bino
Jan 24, 2010 05:10 PM
dsm1990gsx
Sep 21, 2008 07:41 PM
shreff99
Nov 22, 2006 02:12 PM
