Getting Low MPGs
Old May 15, 2018 | 06:41 AM
SERPENTOR's Avatar
Default Getting Low MPGs
Anyone else getting low miles per gallon? Averaging about 15 to 21 at bests. What psi are you guys using in your tires? It's a 2008 Mitsubishi Outlander XLS V6.
Old May 17, 2018 | 01:26 PM
ccernst's Avatar
what type of commute?
Last summer, I puttered at 65MPH for most of my commute, no A/C (crack passenger front and driver's 2nd row windows for good airflow w/o buffeting) and floated between 28-29.5 indicated...I did get one trip that hit 30.1 at the very end. Winter, I got around 26 MPG, indicated. I run 36psi in my tires.
I do have a bluetooth OBDII reader that I use with Torque to watch various sensors. I do have one bank that reads pretty bad LTFT (floats around 7.5-9%...mechanic friend says CEL comes on around 10 or 12%) and the downstream O2 sensor pitches and dips similar to the upstream sensor, all on the same bank...so I think I have a cat slowly dying.
OBDII adapters are pretty cheap, and you can get Torque Lite to read your basic sensors...might not be bad idea.
Old May 17, 2018 | 10:15 PM
SERPENTOR's Avatar
Default City traffic
City traffic and on open highway the best I get is 19-21
Old May 21, 2018 | 10:06 AM
copyboy311's Avatar
My 2007 V6 Outlander has always gotten **** gas mileage. If I'm really lucky, I might get 25 mpg on the highway with a tailwind. Any crosswind or headwind action, and I'm at 22 at best. In mixed driving, I'd say I'm somewhere in the 19-22 range.
That said, I do have a roof rack, which probably cuts down considerably on efficiency. That also said, I'm willing to put up with crappy mileage in a car that's paid for. And further, I'd be happy to know anything I can do to squeeze a little more mpg's out of it.
Old May 22, 2018 | 11:13 AM
ccernst's Avatar
Serpentor, are you using cruise control? are you using air conditioning? what speed are you going? 70 vs 65 vs 55 makes a difference.
in the city, I can see getting about 19-20.
My wife will go 70-75 with AC on...mpg goes down to around 22-23MPG at that point.
Old May 22, 2018 | 06:15 PM
theSaint024's Avatar
I've always gotten less than rated mpg. It's likely the hills where I live, the way I drive, and mostly city driving. If highway driving only, I get within a 2-3 mpg of rated for highway, but I also have more weight in the car than usual. In our V6, I probably average 15-20. On the high side when we actually drive on the highway.
BTW, PSA: Running AC leading to worse gas mileage is a myth. It may have been true when cars were less aerodynamic and not as fast and less efficient, but these days, it's actually just as good if not better to keep windows up and run AC. Cars are engineering marvels these days.
Old May 23, 2018 | 10:10 PM
SERPENTOR's Avatar
No cruise control, yes I use the air conditioner, and drive at 55 - 60 mph.
Old May 31, 2018 | 09:51 AM
copyboy311's Avatar
With summer temps back, my mileage has improved 2-3 MPGs in both city and highway driving. Cold temps really seem to take a toll on the V6 performance, even anything in the 40s or lower.
Old Jun 4, 2018 | 10:34 PM
SERPENTOR's Avatar
Default Weird
Yesterday I managed to reach 25 MPG but there was hardly anyone on the road. I also found out the Fuel Economy from Fueleconomy.gov
https://www.fueleconomy.gov/feg/bymodel/2008_Mitsubishi_Outlander.shtml
Old Jun 5, 2018 | 07:51 AM
slorimer's Avatar
Our 2014 only gets around 12L/100km (20MPG) in the winter but our commute is pretty short 15km, and in the city. We can get to 9L/100km(26MPG) once we're out on the highways. It's not great, but none of the others with a V6 are better.
Wyld Bill
Jul 20, 2015 10:28 AM
jesander
Sep 16, 2013 01:40 PM
lastexile
Nov 21, 2012 02:19 AM
Harold Doran
Aug 13, 2012 01:59 AM
Gray Ghost
Aug 26, 2011 07:26 AM
