getting remote key off from its slot on dash of Outlander 2014
Hi
I bought the new gen 2014 Outlander and got the remote key inside the slot on the dash but can not get it out!!!
Is there a botton or so to get it out??
Thanks
Thanks
Thank you for your help and suggestions
Yes the car in Park and light switched off. What I need is some one got similar vehicle to tell me how he get his key fob out from the insert hole in the dash.
thanks again and looking for solution
The key fob just goes in an out without any effort on my 2014 Outlander. There is no lock of any kind at all. It is just a small open compartment a little to the right from the 12V DC plug on the dash right in front of the gear switch lever.
The remote is supposed to stick out at least 3/4 inch when fully in. Maybe the plastic casing inside at the back separated when someone used too much force previously and you managed to jam it in between the top and the bottom piece. Just a guess
I normally keep the garage opener remote in there instead of the key fob. It is a perfect fit in my case
