Good tire for 08 Outie ?
Old Apr 2, 2011 | 08:54 AM
firstorbit84's Avatar
tirerack says that a new lancer tire is 205/60/16, not 205/80/16...
also, would wrecking the gearbox by using two different diameter tires only apply to 4wd models, or 2wd models when the two odd sized tires are on the drive wheels (front)?
Old Apr 2, 2011 | 06:28 PM
mahicks3322's Avatar
If it is for the 18" package I can recommend Michelin Primacy MXV4. I have a 2008 XLS with 35000 miles on it. It came with the Goodyear Eagle 2's on it and they only lasted until 34500. I had some alignment/suspension tread wear wear but overall the tire just didn't last and always had A LOT of road noise.
The Michelins are SUPER quiet, have a really nice ride and have a much better warranty. I really couldn't be happier with them because my vehicle is quiter and rides smoother than I EVER THOUGHT POSSIBLE even when it was brand new. It is a total night and day difference.
Old Apr 2, 2011 | 07:24 PM
my '09 SE with 18"s has the original Goodyears on it now, as it only has about 15k mi. on the clock. however, they already look about 60% worn, so I'm not expecting them to last much past 25k.
Thanks for the tip I'll definitely consider the michelin's.
Old Apr 3, 2011 | 03:01 AM
callross56's Avatar
I should have said that the rim from the Lancer fits the Outlander. The 205/80/16 tyre is needed to keep the same diameter as the 235/70/16. The tyres must be the same diameter regardless of 2wd or 4wd as it affects the traction control and the stability control. apparently the computer does'nt like it.Especially if it is on the back.
Old Apr 3, 2011 | 03:03 AM
callross56's Avatar
I forgot to add that the local Mitsubishi dealer gave me the steel rim off a Lancer as a lot of people fit alloys and they scrap the steel rims.
Old Apr 4, 2011 | 09:57 AM
pilcan's Avatar
Callross said: Once you replace your tyres with 235/70/16 then you can't use your stock temp use tyre or it can wreck the gearbox as it is a different diameter.
Can I use my stock temp tire if I have 235/65/R16?
Is there anyone among you guys install 235/65/R16 on your Outie? Any experience with this size?
Old Apr 4, 2011 | 10:10 AM
Claude_A's Avatar
Yes, since it will be within .6% of the original.
Have a look at the attachment made at the Miata tire comparator.
http://www.miata.net/garage/tirecalc.html
Old Apr 5, 2011 | 05:36 AM
callross56's Avatar
235/65/16 tyres are a lot harder to find than 235/70/16 if you can find them at all.
Old Apr 9, 2011 | 07:09 PM
armymen's Avatar
Thanks for all the answer guy
i order a pair of BF Goodrich Long Trail T/A Touring tires (P215/70R16)
thanks again
eddyhondro
Dec 1, 2011 10:22 AM
ltwarren
Jan 29, 2009 05:13 PM
zontarh
Mar 9, 2007 11:46 PM
TinkerMan
Nov 10, 2006 01:07 AM
5Tizzle
Feb 7, 2006 05:09 PM
