Help! Brokers spark plug in head
Old Mar 6, 2020 | 07:22 PM
Dave Schmidt's Avatar
Default Help! Brokers spark plug in head
Ok, so I have a 2007 outlander 3.0 that has a broken plug stuck in the head. It broke off flush the the threads. I got the ceramic out. Then was using a easy out to remove the rest. Boy am I lucky on top of the broken plug I now have a broken easyout in the head as well. What do I do next? Also how hard is it to remove the head? And DIY’son it. Mechanically inclined but still prefer to see a write up or video on it.
thanks
Old Mar 9, 2020 | 01:40 AM
Christopher R. Rhoads's Avatar
Hello Mate,
It sounds like you have a lot on your hands at this point, I can't see anyway you can do this without pulling the head. With an Easy out in there you now have tool steel that is just going to deflect any drill bit that you use to the softer metal of the head.
It sounds to me like you are in for pulling the head. This would be a good moment to get the head refreshed, new head gasket and new timing setup. This is a costly repair and very time consuming. How much experience do you have? Pull the head isn't too bad, it just requires a lot of work and a list of torque specs. You'll just need to see if there are any specialty tools or anything.
Old Mar 9, 2020 | 10:48 PM
ccernst's Avatar
Car-part.com has 3.0L head for 200 a pop....think about cost to have yours serviced....
hellgrace5
Dec 15, 2010 05:10 PM
dsmbuilder
Jul 17, 2007 12:33 AM
#1 Stunna
Jun 7, 2007 05:59 PM
spyder4g63t
Oct 30, 2006 09:07 PM
AngelViper33
Aug 12, 2004 02:47 AM
