2016 2.2diesel - 'lumpy' idle and missing
Old Dec 30, 2019 | 11:35 AM
reds's Avatar
Default 2016 2.2diesel - 'lumpy' idle and missing
Hi all,
After a bit of advice. We recently bought a 2016 with high mileage. We are experiencing a strange momentary 'loss of power' like its stalling at various speeds. It happens mainly at lower revs between 1200 and 2000 but can happen at higher revs. we can't find a pattern or any one thing that makes it happen.
It has full Mitsubishi service history (83k) and is very clean and appears looked after.
We have been back to the garage and it isn't throwing out any fault codes but they have agreed to take it back in and look at it over a longer period. They have agreed that they will do what's needed to rectify but seem to be at a bit of a loss as to what it is.
Any pointers?
Old Mar 8, 2020 | 04:16 PM
reds's Avatar
for anybody interested, it was a tiny split in the turbo hose that only manifested when not under power.
Old Mar 8, 2020 | 04:33 PM
Outey2016's Avatar
Thank You.....
I am in the middle of diagnosing some similar issues...
I had a cracked 'intercooler'' to 'throttle body' hose that I replaced
When doing so I sprayed the throttle body butterfly valve with some break cleaner and verified it was moving freely
1 day later my wife said it wasn't running right and was down in power, on checking it was throwing a P0107 error (MAP Sensor) but as far as I can determine the MAP is good. It is outputting 1 Volt at idle which is about normal. Today I disconnect the battery and then reconnected after 5 minutes then allowed engine to tick over at idle to relearn its nominal air fuel mix. I have taken car for a quick spin and all seems ok now....its it not throwing an error any more....will test drive more tomorrow.
Old Mar 10, 2020 | 02:59 PM
reds's Avatar
i had no errors. Thankfully the garage i bought to from was very helpful and pretty much replaced everything they could until they found the issue.
Mitslandur
Aug 16, 2018 03:11 PM
oliveros1983
Jun 27, 2017 12:14 AM
Landsharkk
Feb 28, 2016 12:19 AM
yamahablaster8230
Aug 29, 2006 09:28 AM
iwilli1169
Jun 17, 2004 08:09 PM
