Help Please! 07 Outlander P2141 & P0487
Old Jul 14, 2014 | 01:43 PM
2007OutlanderElegance's Avatar
Default Help Please! 07 Outlander P2141 & P0487
Is anybody able to help, my 07 Outlander has had the error codes P2141 & P0487 for some weeks now. I've had it in the garage and the replaced the EGR but its not cleared the errors. Now tonight on my way home from work there was a kind of pop and its gone into idle mode, sounds like major blowing when you accelerate and smokes in 1st and 2nd gear. I have a major drive of some 800 miles from Saturday and I really need to direct the garage who seem baffled.
Many thanks for any advise you can give.
Old Jul 14, 2014 | 04:44 PM
ccernst's Avatar
The only thing I found:
p0487 and p2141 - Dodge Cummins Diesel Forum
Maybe look around the throttle body for a loose/disconnected connector.
Old Jul 15, 2014 | 09:17 PM
Mitsu Outie's Avatar
DTC Code P2141
DTC Code:P2141Description: Exhaust Gas Recirculation Throttle Control Circuit Low Probable Causes:
  1. Sensor or solenoid faulty
  2. Connector terminal contact is damaged or corroded
  3. Wire harness - Check harness for correct voltage, open, short to ground or short to voltage
  4. Update control unit software - Check for the latest control unit update
  5. Powertrain or Engine Control Module faulty
  6. EGR components clogged, dirty or leaky
Old Jul 15, 2014 | 09:18 PM
DTC Code P0487
DTC Code:P0487Description: Exhaust Gas Recirculation Throttle Position Control Circuit Probable Causes:
  6. Exhaust leaks or restrictions
  7. EGR components clogged, dirty or leaky
  8. EGR valve damaged/defective
krismartin001
Jul 5, 2024 08:35 AM
redlancer
Sep 5, 2015 01:56 PM
iceno9
Jun 17, 2013 10:43 AM
catacami
Mar 19, 2012 08:36 AM
BrianWSNC
Oct 16, 2008 08:22 AM
