HID Conversion DONE! (Pics and info)
#101
(short back ground , I installed foglights and wired it to the parking lights as the trigger for the foglight relay, this was done so that she never forgets to turn them off and i did not have to install a switch)
so when the noise finally came oni traced it back to the relay for the foglights, the only reason why i can think this would happen is because it is not getting a full 12 volts
any thoughts
#102
so i did the above mod ,switching the wires from the headlight harness and it seemed to work fine, but just tonight my wife came home (here Outie) and said her car is making a funny noise.
any thoughts
any thoughts
#104
Well, once you switched the wires - your parking light circuit is no longer producing 12V!!! It does produce constant 12V prior to modification and this is why I switched them, so that I can use it for low beam HID relay. In your case, you shouldn't do this mod - just wire-tap fog lights relay to stock parking lights wiring. BTW - if you have not switched to HID relay kit for low beam, your parking light circuit is now been overloaded by stock low beam lights - beware!
everything is switchback to the way i first had it. I am for sure running a HID relay kit would not install it with out one
and jaysfreak i took the bumper off to install the foglights
#106
and I answered it for you. I tried to help you and did everything but purchase the bulb and install it for you. wtf
Quote:
Originally Posted by armymen
Cool but probably still need to MOD my light for that ?
I ask more detail from the company will see what they say
The owners manual says that the low beam bulb is 9006HB4. I believe that if you can find that type of base/plug, you should be good to go. It is a common base. Good luck!
This should help.
http://www.lightbulbs4cars.com/site/1567293/page/823788
__________________
so theire is no different light i can put with a more white
what kind of mod i need for the HID?
can the dealer do the change ? costly ?
kind of look wierd now led ligh like a audi its ok but with the park light LED with the normal yellow light look funny :s
My buddy has these type of bulbs.
They arent too bright and look cool.
http://www.coolights.com/Headlight-Bulbs_c_233.html
Last edited by RAMON-; 10-07-2010 at 06:48 PM. Reason: Adding redundant information. Posted elsewhere
#107
You asked the same question here https://mitsubishiforum.com/forum/sh...ad.php?t=36861
This should help.
__________________
This should help.
__________________
im stupid haha ;P
So an other question
from that website, http://www.lightbulbs4cars.com/site/1567293/page/823788
Crystal White that is white like a LED light or HID like right ?
( before i order and cry because wrong colors, lol )
it also say : FOR OFF ROAD OR SHOW ONLY . ????
And are they as bright when i drive as the factory one ? As perfomance ?
thanks again :O
#108
haa sorry lol
im stupid haha ;P
thanks again :O
im stupid haha ;P
thanks again :O
I believe they are. It would be great for the manufactures to have a standard name and description for their bulbs. Its kinda confusing. Just my opinion....for low beams keep they 55 watt or under. this link may be more helpful.
http://www.lightbulbs4cars.com/site/1567293/page/926443
Here I a nice description....
http://www.lightbulbs4cars.com/site/...roduct/CWHB455
#109
Hehehe
yes its kind of confusing
