HID Conversion DONE! (Pics and info)
Old Feb 24, 2014 | 10:53 AM
  #191
jdpaul198's Avatar
This was the connection i did according to the diagram provided in the box. The two ends from the bulbs then go directly to the factory cable. The cancelers does avoid the flickering. I have zip-tied everything securely for now, will try to take a picture of that as well.
I still have the problem with the DRLs I guess. I have to leave the headlight on to use the HIDs in the day, I don't know if that's a problem but it works for me. If there's a solution to that as well please let me know about it !!
Old Feb 24, 2014 | 12:11 PM
  #192
Vadimus's Avatar
You can switch DRL mode to let you HIDs work as DRL.
Old Feb 25, 2014 | 04:39 AM
  #193
danthe's Avatar
so,basically,with cancelers, I don't need harness and capacitor?
Old Feb 25, 2014 | 10:40 PM
  #194
jdpaul198's Avatar
I am not sure what's DRL mode. I tried that and the HIDs don't turn on. I have to switch the headlights on completely for them to turn on.
Old Feb 25, 2014 | 10:42 PM
  #195
jdpaul198's Avatar
The cancelers itself are capacitors. I didn't use a harness but some members advised me to do so. I tried it without the harness and it worked for me.
Try it without the harness first and then bother spending more on it.
Old Mar 16, 2014 | 05:23 PM
  #196
danthe's Avatar
I finished installing without harness,but now I have question... when lights are on 'Auto',they are turned on when ignition is on, and then when starting the car,lights are cut-off,and when engine is on,lights are back on too... is there some way to disable lights on 'ignition on' ,and to set lights-on only when engine is running? (because I don't believe bulbs will last long when they are turned on two times on such short interval)
Old Mar 17, 2014 | 10:51 AM
  #197
Vadimus's Avatar
Stock HIDs act same way so I guess that's fine.
Old Mar 17, 2014 | 02:02 PM
  #198
danthe's Avatar
well stock bulb costs much more than aftermarket-chinese-unknown bulb,so that was my main concern worst thing is that we don't have authorized mitsubishi service in my country,so I don't have anybody to ask can this be reprogrammed somehow,or to try to do some hardware trick...but in worst case I will leave it as it is now
Old Mar 18, 2014 | 05:56 AM
  #199
MM3Canuck's Avatar
Even IF a bulb burns out. You get a new pair of bulbsfor $15-30. IMO, you shouldn't lose sleep over that.
Old Oct 30, 2015 | 04:43 AM
  #200
caskey_b's Avatar
bumping this thread... here is my HID install on my 2013 Outlander SE
https://mitsubishiforum.com/forum/mi...2013-se-48901/
