HID install on 2013 SE...
Old Oct 11, 2015 | 06:15 PM
caskey_b's Avatar
Exclamation HID install on 2013 SE...
Will be installing HIDs on low and high beams in the morning...
Opt7 Boltzen Canbus Series with relays and capacitors...
OPT7 Boltzen AC Canbus Series: 35w HID Kit
OPT7 HID Kit Wire Relay Harness Anti-Flicker - Opt-7
OPT7 HID Kit Capacitors Warning Light Cancellors (Pair) - Opt-7
stay tuned for pics!!
Old Oct 12, 2015 | 11:42 AM
caskey_b's Avatar
Halogen low with halogen fog...
Halogen high (obviously with low halogen too)...
5000k HID low with halogen fog...
5000k HID low with halogen high...
5000k HID low and 5000k HID high...
Old Oct 12, 2015 | 11:45 AM
caskey_b's Avatar
Road view....
Halogen low...
5000k HID low...
5000k HID high and low...
Old Oct 12, 2015 | 11:58 AM
caskey_b's Avatar
The kit...
Anti-flicker capacitor hooked up to ballast...
Very high quality kits! Best I've bought!
Old Oct 12, 2015 | 12:04 PM
caskey_b's Avatar
Installing bulbs is pretty self-explanatory..
Here is where I grounded both relays. It's on the driver side right in front of fuse box under hood.
You will see I labeled every single connection (high and low) when installing. Once wires are tucked away neatly, it's very difficult to follow wires if you do end up needing to replace a bulb, ballast, relay, etc. Precautionary measures!!!
And hot relays got hooked directly to positive lug on battery...
Old Oct 12, 2015 | 12:07 PM
caskey_b's Avatar
Next tucked high and low ballasts away for driver side...
Then cleaned up relay wiring behind driver side headlight...
Old Oct 12, 2015 | 12:11 PM
caskey_b's Avatar
Routing relay wiring to passenger side of vehicle...
Under intake mounting location..
And above radiator, tucked away under this panel (can see zip-ties where relay wiring is hidden underneath)...
Behind washer fluid fill neck on passenger side...
And ballasts for passenger side lamps I could not mound exactly the same way as driver side without cutting and splicing relay so they are mounted a little different.
Old Oct 12, 2015 | 12:17 PM
caskey_b's Avatar
*********IMPORTANT NOTE IF DOING HIGH BEAM HIDS**********
This particular model year, 2013, and I would assume all other 2010-2013 at least, have a dust cover that screws on for the high beam bulb... You will have to drill a 7/8" hole next to the factory grommet that allows the factory wiring through...
The good news is this kit come with a rubber grommet so a 7/8" hole is perfect and I silicone'd it up after to ensure a good seal (better than the factory grommet seal in my opinion).
Old Oct 15, 2015 | 04:04 PM
caskey_b's Avatar
Road pics updated...
Night and day difference between halogen and HID. I adjusted the height a little after installing the HIDs, they were a little too low and could really tell after installing the HIDs.
Excellent light output now!!!
excoboy
Oct 27, 2011 04:31 PM
2011GT
Aug 8, 2011 11:19 AM
NJ3kgtSL
May 8, 2009 05:05 PM
BrunoBoy650
Apr 10, 2007 03:27 PM
