High-speed shakes
Old Dec 27, 2017 | 08:43 PM
kev994's Avatar
Default High-speed shakes
I noticed recently that my 2011 Outlander V6 AWD shakes rather fiercely above 70 MPH (120km/h) (I don’t get that fast often). I had just installed the winter tires/rims so I assumed I needed them balanced. That seemed to help but it still shakes quite a bit. I notice nothing at all until I hit 70. If I’m accelerating or going up hill it doesn’t shake at all. If I let off the gas, go faster, go downhill, or turn either direction it gets worse. The steering wheel is moving rapidly side to side about 1/4 inch. Brakes are new and smooth. I’m going to check what happens if I shift to Neutral, any other ideas?
Old Dec 28, 2017 | 08:42 AM
kev994's Avatar
Update: shifting to N has no effect so I’m thinking wheel or suspension.
It actually starts shaking a bit lower than I thought, about 60 mph but almost imperceptible.
Old Dec 28, 2017 | 06:14 PM
quadcam's Avatar
Maybe a wheel out of round.
Old Jan 1, 2018 | 05:27 PM
kazlas's Avatar
Was it shaking before you put winter tires? If no, then your problem is in your new tires.
Old Jan 2, 2018 | 07:24 AM
kev994's Avatar
I didn’t notice shaking before, but I never went fast enough. The first step is obviously to swap the tires, but it’s about to snow. I’ve been hearing rattling in the front end when it’s cold but it dissipates after a couple miles of driving so I’m going to check for play while I have it jacked up. Thanks for the ideas.
mjbw372d
Mar 17, 2007 09:02 AM
Exist
Feb 22, 2007 07:05 AM
Eclipseprince
34
Jan 13, 2007 09:37 PM
Lil red
Jun 11, 2005 10:04 PM
Angel_408
Mar 1, 2005 05:20 PM
