Hood dents at Hinge Location (2007 XLS)
Old Jul 6, 2010 | 06:22 PM
  #91
seajack's Avatar
I installed 2008-2009 kit in 2007 outi.with NO trouble.
Old Jul 8, 2010 | 06:34 PM
  #92
klas's Avatar
So, is this kit just for fun or it will prevent something?
Old Jul 22, 2010 | 01:36 AM
  #93
klas's Avatar
So I got the kit and was about to install, but documentation is vague and I don't want to mess up something. Can someone explain to dummy please if these are the points where I need to install ?
Old Jul 23, 2010 | 12:10 AM
  #94
klas's Avatar
So anyone knows how if I am installing it correctly from pics above?
Old Jul 23, 2010 | 01:25 AM
  #95
seajack's Avatar
Yes! that is where you put fittings. Hood bolt will seem short and needs thin washer.Put both struts on before trying to close hood.
Old Jul 23, 2010 | 01:30 AM
  #96
seajack's Avatar
sent reply too fast. top fitting needs strut attaching point towardsouter edge of hood.
Old Jul 23, 2010 | 03:24 PM
  #97
klas's Avatar
Thank you for details!
Just to confirm:
The top attachment goes on top bolt and the strut attaching point towards the edge of the hood. I thought I tried it and there was not enough space, but I'll try it again.
The bottom attachment goes in place of that bolt that holds the headlight like shown in the 3rd picture.
Old Jul 23, 2010 | 04:57 PM
  #98
seajack's Avatar
Look at picture #1,flip ball over to hood edge. make sure bracket is marked for proper side . small (L)or (R).
Old Jul 23, 2010 | 05:40 PM
  #99
klas's Avatar
If I understand you correctly and flip it, it will not be flush with the hood. I will double check tonight. Thank you for your help!
Old Jul 23, 2010 | 09:07 PM
  #100
seajack's Avatar
Klas, look on the instruction sheet lower right side marked (completion Guide).It shows proper facing of the bracket on the hood.
