How to install oem mudguards
Old Nov 15, 2010 | 01:26 AM
SERPENTOR's Avatar
Arrow How to install oem mudguards
I have a 2008 mitsubishi outlander and I just bought the oem muguards, did you guys remove the tires to install or is there a way to put them on without taking off the tires?
Old Nov 15, 2010 | 09:08 AM
nesser's Avatar
I was able to install them without taking the wheels off. Turn the front wheels depending which side you are working on for more clearance.
It's the lower screw inside the wheel well on the rear wheels that is a bit of a tight fit to install.
Used a 3/8-inch air ratchet with a phillips head socket. You might need an extension with a U joint to get to that one screw or a long screw driver. I forced the ratchet into the wheel well on a bit of an angle. It still caught the backing clip and straightened out as it went in.
OTO27
Nov 14, 2008 04:07 PM
djnman
May 6, 2008 07:04 AM
Cuffy
Apr 20, 2008 10:44 AM
rdenis
Jul 4, 2007 02:23 PM
maharajah
Mar 24, 2007 02:13 PM
