How to make new phonebook entries in XLS
Old Apr 17, 2007 | 06:28 AM
budh's Avatar
Default How to make new phonebook entries in XLS
I've read the literature for my new XLS and although it mentions how to edit or delete an entry from the "Phonebook" used with the hands free Bluetooth system, it never mentions how you ADD a phonebook entry.
How is this done? Is it by voice only, or is there a way to input from the panel in text mode?
Bud H
Old Apr 17, 2007 | 06:49 AM
rcpax's Avatar
Default RE: How to make new phonebook entries in XLS
From my experience, it's voice entry mode only. Haven't figured out if it's ever possible to do it manually. It's probably only by voice because this is how you call people using the handsfree BT system phonebook, although you can dial manually from the MMCS panel just as you would from the phone keypad.
Old Apr 17, 2007 | 01:09 PM
sbessel's Avatar
It's voice only...
There is very little integrationin the Navigation unit for BlueTooth... There is a small status window on top, and a hard to find screen that allows you to dial numbers, but no phonebook entries. No dialing of POI or address entries in your navigation system, they are seperate. Very much like the BlueTooth was an afterthought.
Old Apr 17, 2007 | 03:25 PM
JMC's Avatar
JMC
It'll see your phone...but as far as sending the contacts of your address book it's a slow process. I can send a contact via bluetooth to the Navi...but then I can find where it puts the contact. I took some time and just "voiced" certain contacts I use all the time. I've also found that the bluetooth has trouble with certain contact that start with the same letter.
Old Apr 17, 2007 | 10:16 PM
soundcolor's Avatar
get a yellow pages, slid it in the passenger seat and BAM... all the phonebook you'll ever need
petercanada
May 6, 2016 05:16 PM
Luppie
May 4, 2014 04:44 AM
Thundersky
Mar 3, 2013 01:03 PM
Hollywood2306
Aug 5, 2012 12:39 AM
rkmoray
Jul 14, 2010 07:36 AM
