I need help with hitch install
Old Aug 9, 2013 | 09:56 AM
JRK5892's Avatar
Default I need help with hitch install
2010 outlander
what a nightmare... first i wanted my hitch to color match.. so i stripped it, blasted it, and color match powder coated it... was a bitch to move that big sucker around in the blast cabinet as well as having to take it from the oven to the booth twice as it needed a clear coat... i thought my troubles where behind me... ooh no!
install, I used a tap to get fresh threads, drivers side worked out no problem, smooth as glass, the passanger side however... 2 of the welded nuts where just destroyed... the threads where just shot, so i had to retap them to standard 1/2, and run larger bolts in... hitch is mounted up.
now the issue... rear wiring was 1-2-3 plug and play no problem.. i go to hook up the front harness to the battery and NO PLUG! i have searched high and low, actually had 4 guys looking and we where lost, pulled the battery, nothing under the tray, followed the wire harness by the lamps, nothing... any ideas? i am at a loss and about done with this 4 hour hitch install, pathetic... was a nightmare
looks good as hell though with the color match. the truck is very dirty now so the pics are a bit off, ill get it washed and take some good pics... this is the same color i am giong to use on the lips of my wheels with flat black centers
if you have any idea where i should look for the plug for the front wire harness please let me know!!!
Old Aug 9, 2013 | 01:22 PM
JRK5892's Avatar
well i broke down and went to the dealer, tossed a service guy $5 and he showed me where it was... jesus not at all like is said in the instructions or on here, it was taped to a lower harness going to my fogs! way way down there... all done, washed her up and snapped some pics in the light. very pleased
Old Aug 9, 2013 | 06:59 PM
firebuck's Avatar
Looks nice. Funny how it is not exactly where you think it is. It took me a while to find ours as well.
Old Aug 10, 2013 | 07:40 AM
milliesdad's Avatar
On my 2011, instructions said "black connector taped to right headlight housing."
It was a gray connextor taped to the headlight housing loom, near the core support.
The give-away is 1 red wire in a 4 wire connector.
Sounds like you went for the Mitsu connector. A little pircey but the only way to do it. I got my 2012 with the tow package so I didn't have to go thru this.
What brand hitch. I went with a Curt and everything was plug and play.
Old Aug 12, 2013 | 12:41 PM
JRK5892's Avatar
I used the Curt as well, but the welded threads where destroyed on 2 of the holes in my frame, so i had to retap them so i can get it to snug up... ya the harness was plug and play and worked out great once i knew where that plug was ahhaha, pulled the trailer all weekend and it worked flawless!
Old Aug 21, 2013 | 11:56 AM
OutlanderGT's Avatar
Thats great that you got the dealer to show you where it is without paying much $
I put a aluminum tape over the holes as soon as I bought my car, to keep the dirt and corrosion down.
daehnomel
Nov 4, 2020 04:59 AM
piper
Aug 13, 2020 01:46 PM
saifthamer83
May 11, 2010 03:51 AM
chili_g
Apr 27, 2008 08:48 PM
roach
Oct 6, 2007 08:00 PM
