IDLE problem 04 Mitsu Outlander
Old Apr 12, 2013 | 12:24 AM
demoneyz's Avatar
Default IDLE problem 04 Mitsu Outlander
hi guys just want to ask what could be the problem when i turn on aircondition the idle on my outlander drops to almost shutting down..could it be the TPS? O2 sensor or something?
Old Apr 12, 2013 | 12:44 AM
mxmikie's Avatar
could be the iac
Old Apr 12, 2013 | 08:18 AM
ccernst's Avatar
I'd had a TPS go out on a Grand Prix, it went into a limp home mode. the engine would barely rise in rpm at all, regardless of how much gas I tried to give it. i'd start with the IAC (something you can clean yourself) or the tps (very cheap part and also generally easy to replace).
Old Apr 13, 2013 | 08:40 AM
demoneyz's Avatar
thank you guys..maybe ill start with the IAC first then go from there..
Old Apr 19, 2013 | 09:38 PM
BrianB's Avatar
If you find the IAC, can you please let me know where it's located.
Brian
Old Apr 20, 2013 | 08:03 AM
milliesdad's Avatar
It sounds like the compressor clutch is dragging or the relay to increase engine rpm os bad.
Anyway, look for a problem in the AC circuitry-electric
BrianB
Jun 5, 2015 05:10 PM
out lex
Nov 10, 2010 08:50 PM
beerbaron105
Aug 13, 2010 08:24 AM
alavr002
Oct 9, 2008 01:24 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
