LED light (audi style) for outlander :) DONE , Now how to i pass a wired inside ?
Old Sep 15, 2010 | 09:16 AM
  #21
tfaas's Avatar
[quote=armymen;263020]I install this today,
So Far i plug it on the full pump fuse, as its the only one i figure when i turn the key at the second click, will turn the light on. If somebody know how to install wired inside or for the first click to put the light on, let me know
( sorry im french and my english writing is no good, lol )
When I back lit my Mitsubishi grill emblem I piggy backed off the radio fuse and it comes on with the first click.
Attached Thumbnails LED light (audi style) for outlander :) DONE , Now how to i pass a wired inside ?-12-19-09_1752.jpg   LED light (audi style) for outlander :) DONE , Now how to i pass a wired inside ?-12-19-09_1751.jpg
Old Sep 15, 2010 | 09:34 AM
  #22
armymen's Avatar
Did you use a inside fuse or outside. Of the cab ? The only thing to do with the radio on the outside fuse is amp but its always on. If you use the inside fuse where did you pas the cable ??? And how
Old Sep 15, 2010 | 10:31 AM
  #23
White Out 2010's Avatar
Originally Posted by armymen
So HID headlights all you have too do is change the bulb ? Or do more mod ?
H.I.D. stands for High Intensity Discharge. HID Bulbs need a ballast to be powered. You dont necessarily need to do a mod to your car. An HID kit is actually plug and play for some cars. But for others, like my 2010 Outlander, i needed a relay harness which get a little complicated to install, but still easy.
Go to DDMTuning.com to purchase an HID kit. Most newer cars need a relay harness for the HID kit to work.
Old Sep 15, 2010 | 10:48 AM
  #24
I just change also my park light at the front for 2 LED.
So now i have the 2 LED strip, + LED park light at the front
So i wonder, can i change all the LIGHT to LED ?????
Will i still see good at night ?
If not is there some bulb, WHITE, like LED and still see good that i can just put without any other modification ??
It is actually against the law, especially here in NYC to change the color of your signal lights, and parking lights to any other color but AMBER. The reason for this is that AMBER is visible day and night. White tends to become hardly, visible during the day, especially on a sunny day.
The other lights that i could think of that you can change that is legal would be the dome lights, license plate lights, and maybe reverse lights, which Im actually going to do as well.
Old Sep 15, 2010 | 10:55 AM
  #25
Hey tfaas, thats pretty cool the way you backlit your emblem. Show us or tell us how you did it so we may do it in our cars as well.
Old Sep 15, 2010 | 02:29 PM
  #26
tfaas's Avatar
I used three 4.5 mm smd led strip I bought off eBay. I pryed off the badge, which is held on with some kind off putty type adhesive, drilled a hole where the three diamonds meet and put one strip under where each of the diamonds sit. I ran the wires throught the hole I drilled to a piggy back fuse i put in the under dash fuse block. Then I super glued the badge to the led strips. I aslo put in bullet connectors so if I ever have to remove the grill I don't have to cut the wires. I wanted to use white, but I already had red ones.
Attached Thumbnails LED light (audi style) for outlander :) DONE , Now how to i pass a wired inside ?-tl-09020-al-2.jpg
Old Sep 15, 2010 | 06:02 PM
  #27
RAMON-'s Avatar
so theire is no different light i can put with a more white
what kind of mod i need for the HID?
can the dealer do the change ? costly ?
kind of look wierd now led ligh like a audi its ok but with the park light LED with the normal yellow light look funny :s
My buddy has these type of bulbs.
They arent too bright and look cool.
http://www.coolights.com/Headlight-Bulbs_c_233.html
Old Sep 15, 2010 | 06:18 PM
  #28
armymen's Avatar
Cool but probably still need to MOD my light for that ?
I ask more detail from the company will see what they say
Old Sep 15, 2010 | 06:26 PM
  #29
RAMON-'s Avatar
The owners manual says that the low beam bulb is 9006HB4. I believe that if you can find that type of base/plug, you should be good to go. It is a common base. Good luck!
This should help.
http://www.lightbulbs4cars.com/site/1567293/page/823788
Old Sep 15, 2010 | 06:30 PM
  #30
armymen's Avatar
tfaas You still did not tell me how you plug it to the radio : )
