Link BETWEEN CVT and Transfer Case.
Old Jul 28, 2021 | 04:33 AM
sheikmohamed's Avatar
Question Link BETWEEN CVT and Transfer Case.
Hello Guys,
I would like to know outlander 2009 2.4 4b12 shares CVT fluid in the transfer Case?. Ref#VIN- JMYXTCW5W9Z702186. During removal of the transfer case fluid, green color CVT fluid came out and the quantities are close 3 to 3.5 liters.
When my mechanic fills CVT fluid through the transmission fill hole then it's come out via the drain plug of the Transfer case.. (We kept drain plug open to check whether its coming or not)
Most of 2009 outlander manual found on web, recommends SAE 90 grade oil and the qty is 0.49 ltr but how come mine is having a different fluid and qty ?. Is my transfer case seal broken and this makes cvt fluid leak to the transfer case ?. Is it possible?. . But I don't have leaks any were in the transfer case or in transmission it's all clean.
Old Aug 8, 2021 | 09:11 AM
Truwarrior22's Avatar
Originally Posted by sheikmohamed
Hello Guys,
Transfer case with AWD should be a 10mm hex, is this the drain you used?
Old Aug 8, 2021 | 09:18 AM
Yes we opened drain plug of the transfer box not the tranny cvt fluid drain bolt.
Mikiekmitsu
May 10, 2021 09:23 PM
sheikmohamed
Mar 2, 2021 10:47 AM
tcp
Oct 13, 2020 12:10 PM
Chef
Oct 7, 2018 06:50 PM
jcasaccio
Apr 26, 2007 08:12 PM
