Location of Oil filter in 07-08?
Old Sep 30, 2008 | 01:00 PM
klas's Avatar
Default Location of Oil filter in 07-08?
Does anyone know where the oil filter located? I don't want to take anything apart just to look at it, but is there an angle and place where I can take a peek at it? I want to make sure that none MS dealer installed correct filter. Thanks guys!
Old Sep 30, 2008 | 01:11 PM
azjake's Avatar
Default RE: Location of Oil filter in 07-08?
This is for the 2.4L gas (petrol)engine. Just crawl underneath the outtie from the front, look up, and you can't miss it. It hangs down near the oil pan. Because of its location you can not access it from underneath the hood.
Old Sep 30, 2008 | 01:19 PM
Shambala's Avatar
If I remember correctly in the v6 it is located in the left side of the engine. I would pop the hook open to check but I got no flashlight with me and the OEM oil filter is black so not something easy to find in a dark garage[&o]
Old Sep 30, 2008 | 01:30 PM
klas's Avatar
I have v6 in US. I looked from top with the hood open and did not see it. Do I need to look from the bottom?
Old Sep 30, 2008 | 01:56 PM
azjake's Avatar
Having the 4 cyl I can not say for sure on the V6, but yes, I would crawl underneath and check for it there. I put down a small rug to lay on, and had plenty of clearance to get underneath my ES.
Old Sep 30, 2008 | 02:45 PM
chenarm's Avatar
I believe that it is in the front, When you are standing in front of the car looking to wards the back, it will be on the right side of the exhaust manifold.
Old Sep 30, 2008 | 03:42 PM
tcp's Avatar
tcp
If you're under the car, just look right above the starter...which it dribbles oil onto when you change it.
Old Sep 30, 2008 | 07:34 PM
ruchuck's Avatar
lol I just changed the oil and oil filter tonight. The filter did dribble on to the starter. I replaced the filter with a Mobil 1 m110. It seemed a little smaller then the mitsu one. I believe I have it in correct but there seems to be a few drops under it. Not sure if it is leftover from when i removed the old filter.
I added 4 quarts of Mobil 1 5w-20 synthetic. Seems like I over filled a little but the manual said the pan holds4 quarts.
________
Chrysler TC by Maserati history
rotag84
Oct 1, 2009 05:12 PM
Ahyc
May 5, 2009 07:12 PM
lancer0594
Feb 5, 2009 06:48 AM
tufduck
Jan 25, 2008 03:24 PM
mysterio2099
Jan 16, 2006 11:03 AM
