Lower control arm help
Old Jan 31, 2019 | 09:28 AM
  #21
07xlsguy's Avatar
Originally Posted by n0c7
I did mine last year. Since I was replacing the whole arm which has a new ball joint already pressed into it I used the pickle fork to disconnect the ball joint from the knuckle. Then undo the other two nuts and bolts.
I was working by myself and I simply used a floor jack under the new arm and a prybar to angle the control arm back in. I also lubed the new bushings to help them slide in(slight spray of WD40) and used a rubber mallet to get things in place. This was the worst part but once I figured out the technique the other side was a breeze.
n0c7, I pm'd you regarding this post
jachin294
May 24, 2016 07:23 AM
jerusry
May 27, 2008 12:35 AM
gsblondie
Sep 11, 2006 09:23 PM
99clipsgst
Jul 22, 2006 12:13 PM
Customshiftboot
Jul 29, 2004 05:17 PM
