minor sidewall breach?
Old Aug 3, 2008 | 08:17 PM
Outlander_Joe's Avatar
Default minor sidewall breach?
I was on a really rough backroad and I think a rough edged pot hole may have done this
http://i64.photobucket.com/albums/h1...8/DSCN3037.jpg
http://i64.photobucket.com/albums/h1...8/DSCN3039.jpg
Now that was two weeks ago and the tire pressure has not diminished
I think it is just a very light cut but is there anything that can be applied to strengthen the area?
I know sidewalls are nearly impossible to fix if the cut is the entire way through
Old Aug 4, 2008 | 12:47 AM
Default RE: minor sidewall breach?
Get that fixed PRONTO
Old Aug 7, 2008 | 07:38 AM
puddy's Avatar
you need to replace that tyre asap before you get a blow out, buy you may need to replace both tyres on the same axle otherwise you may overheat the 4wd system (depending on mileage) see hand book for details
puddy
Old Aug 7, 2008 | 07:48 AM
Printerman's Avatar
I would pull the tire and take a look....
If the inside looks ok ... no mark or anything,,, I would say that it is ok...
If you start to get a loss of air I would replace the tire....
Old Aug 7, 2008 | 08:03 AM
chenarm's Avatar
I have had something similar in the past, I took it to a tire dealer, and after he looked at it, told me not to worry about. I figured that it would have been in his interest to sell me a new tire. He seems to be most concerned about the shape of the sidewall, rather than the surface. If the Structure of the sidewall is damage you should see a bump or deformation.
Your tire damage might be different, than what I had.
Marc
Old Aug 7, 2008 | 07:28 PM
Joel_CA's Avatar
Looks superficial to me. Nothing to worry about. Any structural damage to the tire would result in a "blistering" or "pimpling" of the tire in that area. Keep an eye on it and see if it eventually developes into one- otherwise, you'll be fine. If there isa blister or raised areaat the point of impact- replace it now. Its difficult to tell with just pictures.
JJ
BigZachBoss02
Feb 14, 2011 10:16 AM
Rodz924
Jul 30, 2008 12:00 PM
BrunoBoy650
Jul 12, 2006 10:33 PM
03gteclipse
May 24, 2006 10:43 PM
vertstanggt
Jan 26, 2005 03:38 PM
