Mishibishi outlander 2007
Old May 23, 2020 | 12:15 PM
Angelz's Avatar
Default Mishibishi outlander 2007
I have a 2007 Mishibishi Outlander and right now i have 215/70/r17 tires on it and i am wanting to put 235/65/r16 on anyway i think thats the size of the tires will that work
Last edited by Angelz; May 23, 2020 at 12:41 PM. Reason: I put wrong size and i had to fix it
Old May 24, 2020 | 01:34 PM
ccernst's Avatar
Sounds like someone already changed tire sizes on you. Oem is 215/70-16. Anything different will knock your speedo off.
the size you have chosen will be .4% larger than oem....so pretty close
Old May 24, 2020 | 08:29 PM
Angelz's Avatar
Default 2007 Mishibishi Outlander
But will they be ok to use on my 2007 Mishibishi outlander
Old May 26, 2020 | 09:54 AM
sock puppet's Avatar
Here is a tire calculator that will allow you to compare different sizes to determine the variation: Tire Calculator
Old Oct 17, 2020 | 06:59 AM
purnam's Avatar
Assuming the wheel/rim is unchanged i.e. R16 (16" dia), it's safely possible to upscale until 235/70R16 size. I'm using this as max sized up scaling while accepting the speedo/odo inaccuracies. However, best option would be 235/65R16 to accommodate acceptable speedo/odo inaccuracies.
KayKay75
Jun 15, 2016 05:33 AM
chelsel
Nov 27, 2006 04:57 PM
proutlander
Jan 18, 2006 10:17 AM
Richo
May 31, 2005 01:59 PM
