Mitsubishi Outlander Warrior Parking Sensors Not Working
Old Apr 4, 2014 | 02:54 PM
S11 Mitso's Avatar
Default Mitsubishi Outlander Warrior Parking Sensors Not Working
Apologies if this has been covered in another post, I could not find any specific information that would help me figure out why my rear parking sensors are not working. I also noticed that the boot light and passenger side rear fog light are out.
Before taking the car to a dealership, could you please advise what checks I can perform to decipher the issue.
I have a 07 Mitsubushi Outlander Warrior with the standard rear factory fitted parking sensors.
Thanks
Old Apr 4, 2014 | 08:11 PM
firebuck's Avatar
check for blown fuses?
Old Apr 5, 2014 | 01:55 AM
S11 Mitso's Avatar
Which Fuse is it?
Old Apr 5, 2014 | 08:11 AM
Vadimus's Avatar
Both rear parking sensors and rear fogs are powered through same harness.
Old Apr 5, 2014 | 06:02 PM
firebuck's Avatar
Sorry not really sure which fuse, check the manual or test them all.
Old Apr 6, 2014 | 09:42 AM
S11 Mitso's Avatar
Hi,
I opened the rear passenger panel and checked the fog (dummy light) and rear boot light (not working - bulb is fine). I then checked all the fuses and none of these were blown. I have to now check the back light connection to the sensors ( page 13 - http://www.mitsupartsworld.com/Insta...LANDER_PG1.pdf) to see if the wire is damaged.
My plan of action now is to disconnect the parking sensor wire from the back light wire. If the light starts to work, I will then disconnect one sensor at a time and take it from there.
If the light still doesn't work, I'll run a few continuity tests on the wires.
jimmyrinse
Mar 28, 2015 06:03 PM
dubik
Sep 9, 2013 12:11 PM
mredlancelot
Aug 22, 2013 11:41 AM
chenarm
Oct 21, 2012 02:50 PM
kuyabinid
Other Mitsubishi Models
Dec 22, 2010 01:32 PM
