MMCS amp/speakers setup question
Old Jun 2, 2009 | 06:59 AM
steph1693's Avatar
Default MMCS amp/speakers setup question
I just wonder, does anyone knows the audio system setup? i mean what i know is that the head unit is hook on an amp and there is a sub. Is it a 6 channels amp wich 2 channels are bridge for the sub output and is there a crossover for the sub built in the amp or is the sub hook in the MMCS and it is self powerded? the front speakers are ''component'' or if the tweeters are only hook on the speaker output? I only want to know for my personal knowledge if someday, i want to replace the speakers or the amp.
Old Jun 2, 2009 | 09:54 AM
goldenboy's Avatar
for your reference:
http://www.rockfordfosgate.com/oem/outlander.asp
there is also a system diagram that will answer most, if not all, of your queries
Old Jun 2, 2009 | 12:19 PM
steph1693's Avatar
thank you. Do you know where i can find the wiring diagram ? The system is fine but maybe i will replace the tweeters later.
Old Jun 3, 2009 | 03:30 AM
goldenboy's Avatar
fished this off the web
2007 Mitsubishi Outlander Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
hope this helps
Old Jun 8, 2009 | 08:37 PM
07 blk lab's Avatar
I replaced my front speakers and subwoofer with an aftermarket one, in a 2007 XLS, with a Rockford Fosgate without Navigation. I kept the factory deck and installed a LC6i from AudioControl (high/low level converter) after the factory amplifier. Doing it this way allowed me to install an aftermarket 3 channel amplifier to power the front component speakers and subwoofer. The factory amplifier(I believe) has a built in cross over for the front speaker and tweeter. My setup in the Outlander is easy but requires time to do it. I kept my rear speakers running from the factory deck/amp. The sound quality is great and clear.
Bob_G
Apr 12, 2014 10:20 PM
hotponyshoes
Mar 16, 2012 05:53 PM
joseitopuertorico
Apr 9, 2008 01:58 AM
catacami
Jul 8, 2007 09:42 AM
Sebba
May 4, 2006 09:03 AM
