MMCS installation - RF replacement
Old Oct 1, 2013 | 09:46 AM
mihoo's Avatar
Default MMCS installation - RF replacement
Outlander 2008 European version.
I get MMCS module with back connectors like on the picture:
but after putting out my original Rockford Fosgate (with amp and sub) i have 3 cables with different plugs.
Is there a possibility to connect this MMCS module? Some wires replacement in plugs or something else? Please help.
Greets
Old Oct 1, 2013 | 06:05 PM
11SE2HEAR's Avatar
You will also need the adaptor harness to make the MMCS work. You can see it on the diagram from this website: [S/M]OUTLANDER (CW#)
Click on <Chassis Electrical>, then click on <Mitsubishi Multi Communication System>, and then click on <Mitsubishi Multi Communication System> below that. You will see the parts diagram with all the parts you need to make the MMCS work.
Hope that helps.
Old May 21, 2015 | 11:18 AM
fabioaq's Avatar
hello , after disconnecting the battery and reconnected me appears to insert program disk , what should I do not have the disk
Old Jul 19, 2020 | 11:23 AM
Evangelista Cristopher Calcaño's Avatar
Hola soy de república dominicana y tengo el mismo problema. si pudiste solucionarlo por favor ayúdame.
M.a.S.e
Aug 18, 2013 03:59 AM
xmaxasx
May 3, 2013 12:25 PM
Buster005
Apr 3, 2013 08:43 AM
Blu Sprint
Jun 16, 2011 03:04 AM
fmichiel
May 10, 2011 04:40 AM
