MP3s burned to DVD?
RE: MP3s burned to DVD?
It won't work if you simply burn MP3 files into DVD. You have to make it an "Audio DVD".
TryAudio DVD Creator (about 40 bulks). I've burned hundreds of MP3 music into a single DVD. It works perfect for me and looks likeI gotanother MusicServer on my 07 Outlander.
Hope it helps.
DoubleR
Vancouver, BC Canada
Hope it helps.
DoubleR
Yup. Audio DVDs seem to work fine (I used a DVD+RW). Thanks for the tip.
And a DVD disk is NOT the same as a CD disk. However, in theory, anything you can copyto a CD should also work if you copy it to a DVD (e.g. MP3 files). This does not seem to be the case, however, with the music system in the Outlander... It looks like it determines which software to use (MP3 player or DVD player) based on what format is inserted (it would be interesting to know if a DVD burned to a CD (compressed, of course) will play properly).
Transport
01-15-2006 04:28 AM
