Need HELP installing Handsfee (Motorola T605) in 2009 Outie
Okay - I've ordered two T605 kits (one for the Outie and one for my other vehicle) - first install is the Outie.
What I need to know is more info on the factory stereo (note: I don't have the Rockford system - just the regular one):
Here's a link to the T605 manual:
https://motorola-global-portal.custh...ountry_code/US
and a PDF version here:
http://www.motorola.com/staticfiles/...T605_UG_US.pdf
All info you can provide would be greatly appreciated.
Thanks
- First off - I'm wondering if there is a vehicle adapter harness available to make this job easier???
- Need info on removal of stereo unit (note: this is the single cd unit - not the Rockford fosgate unit).
- Need instructions on integrating in fuse box (haven't done that before - must be max 5amp - how can I tell that?
- How to integrate into 12v vehicle power supply?
- Can I patch into built in steering wheel functions - to take advantage of them?
- Can I patch into the built in mic of the vehicle as well?
Thanks
2009, alternative, car, harness, instructions, integrating, manual, mic, mitsubishi, motorola, outie, outlander, stereo, t605, wiring
