Need HELP installing Handsfee (Motorola T605) in 2009 Outie
Old Jan 20, 2010 | 11:03 AM
Pardy's Avatar
Default Need HELP installing Handsfee (Motorola T605) in 2009 Outie
Okay - I've ordered two T605 kits (one for the Outie and one for my other vehicle) - first install is the Outie.
What I need to know is more info on the factory stereo (note: I don't have the Rockford system - just the regular one):
Here's a link to the T605 manual:
https://motorola-global-portal.custh...ountry_code/US
and a PDF version here:
http://www.motorola.com/staticfiles/...T605_UG_US.pdf
  • First off - I'm wondering if there is a vehicle adapter harness available to make this job easier???
  • Need info on removal of stereo unit (note: this is the single cd unit - not the Rockford fosgate unit).
  • Need instructions on integrating in fuse box (haven't done that before - must be max 5amp - how can I tell that?
  • How to integrate into 12v vehicle power supply?
  • Can I patch into built in steering wheel functions - to take advantage of them?
  • Can I patch into the built in mic of the vehicle as well?
If all this can be accomplished - a much better alternative to the vehicle module - since this one will allow you to stream audio from your iphone and play over bluetooth in your car's sound system.
All info you can provide would be greatly appreciated.
Thanks
newoutlanderfan
Dec 29, 2009 10:14 AM
ShortyRider
Jul 29, 2009 03:45 PM
