Noise from the front while driving on highway between 40 to 60 miles
Old Jan 20, 2010 | 12:22 PM
cybergoogle's Avatar
Default Noise from the front while driving on highway between 40 to 60 miles
my 07 XLS (2wd) is having noise from the front while I was driving on the highway between
40 to 60 miles. checked aligment is OK ... wounder if the balance maybe off .. any suggestion?
Old Jan 20, 2010 | 10:14 PM
ruski's Avatar
what kind of noise?
Old Jan 21, 2010 | 11:08 AM
azjake's Avatar
If your tires were out of balance it would probably cause a vibration. I had this happen on the car I owned before my Outlander. Is it possible what you're hearing is tire noise? As tires wear down their noise characteristics can change.
Old Jan 21, 2010 | 10:56 PM
Thank you for reply .. the noise which I think is from the front tire .. the sounds like "wooo-wooo" or hauling noise.
Old Jan 22, 2010 | 12:21 AM
ccernst's Avatar
a possibility for a "wooo-wooo" noise from a tire could be a broken belt in the tire. has it always been that way? hit a pothole recently?? does the rate of the woo woo correspond to your speed?
Old Jan 22, 2010 | 08:45 AM
thank you ccernst ... the "woo-woo" nise only happied recently .. the noise only happens when the speed over 40 mph
Old Jan 22, 2010 | 04:58 PM
ruski's Avatar
bad wheel bearing? Just a guess.
Old Jan 24, 2010 | 10:16 AM
thanks all for your suggestion ... the front passenger-side tire's balance was off. redo the balance and its good
marybethll
Jun 26, 2021 11:32 PM
cybergoogle
Nov 15, 2010 12:08 PM
ron Kirk
Jul 31, 2005 01:45 PM
bdunn
Dec 1, 2004 03:38 PM
