Odd stuff going on in my outlander
Old Mar 21, 2016 | 04:17 PM
andyf97's Avatar
Default Odd stuff going on in my outlander
On an Outlander 2008 and recently it has started to show for no apparent reason a message "steering wheel lock" and an audible fast beeping like quarter second intervals..
This can happen once an hour or every few seconds, it is very random.
So I sit int he car with or without it running and the message will show and the beeping starts. As soon as it came it clears for a while almost like the car is having fun with me.
It is likely some sensor failing, but which.
Now I know the answer might be go to the dealer.. But we have been having bad experiences with our cars going to dealers lately and coming back worse or with original parts swapped for after market parts. Actually the car was gone to the service for 3 weeks and now it feels like a wreck so I am getting to not trust our dealers.
Any pointers to where i can check would be most welcome.
Old Mar 21, 2016 | 10:07 PM
gggplaya's Avatar
Check your battery resting voltage and electrical connectors on the battery first.
Also, check the battery in the fast key, if you have a fast key. Make sure you only have 1 fast key fob in the car.
Old Mar 22, 2016 | 05:39 PM
andyf97's Avatar
Thank you for replying,
A fast hey is that key which always stays in the ignition?
what do you mean by "battery resting voltage" it is like the voltage a idle?
Thanks again,
Andy
Old Mar 22, 2016 | 09:46 PM
gggplaya's Avatar
Fast key is the one where you don't have to take it out of your pocket to start the car. It's "fast", otherwise known as a proximity key.
The resting battery voltage is after you shut off the car and let it rest for 5 hours without touching anything. The voltage should be above 12.5v on a good battery.
freakygirl1990
Oct 3, 2007 06:49 AM
soundcolor
Mar 21, 2007 12:40 AM
rdenis
Mar 17, 2007 02:09 PM
WGONFAN
Jun 30, 2004 12:02 AM
