oil filter change
Old Jan 5, 2013 | 01:48 PM
ccernst's Avatar
When I resealed my upper oil pan, I had to take off the exhaust y-pipe and starter motor. This gave me a great view of the drain funnel. I noticed that it is only a piece of sheet metal and bolted to the block with a single bolt. This allows the funnel to come away from the block if you put any weight on the tip. I pushed it back up and into the block. We'll see if this helps the next oil change. I believe that when I change my filter out, I may be resting my hand on the funnel, deforming it just enough to let quite a bit of oil to bypass it.
wiseowl
Oct 12, 2011 11:45 AM
Tony123
Jan 27, 2011 07:50 AM
Vadimus
Nov 26, 2010 12:13 PM
lancer0594
Feb 5, 2009 06:48 AM
soundcolor
Jun 20, 2007 08:29 AM
