Outlander 2010 - installation of AUX and USB ports
Old Apr 17, 2017 | 08:51 AM
outlander32's Avatar
Default Outlander 2010 - installation of AUX and USB ports
Hi,
I have Mitsubishi Outlander 2010 with the standard radio system like this one:
How can I install USB port for charging(and playback if possible) and AUX port for music playback. I've found
but the tutorial uses Connect Pro CP60, and I am unable to find that.
Old Apr 21, 2017 | 10:18 AM
ikjadoon's Avatar
I'm not sure on the USB, but the AUX is very simple if you want Mitsubishi's solution:
MZ360136EX (
Amazon Amazon
It comes with an instruction manual, too.
Old Apr 30, 2017 | 08:10 AM
fadilmurati's Avatar
hi there I have mounted aux with a cable to aux input but it wont give sound.
on level 48 sound it give sound like in level 2.
What I can do to give clear sound?
Old May 1, 2017 | 01:41 AM
ccernst's Avatar
you are not the original poster, you've given no detailed information about your vehicle, what kind of aux cable you installed, or what you are using to play music from. Need lots more information since we are not there with you.
Old May 6, 2018 | 12:39 AM
ScorpioRNSWL's Avatar
Mines a RHD drive model - but the same radio. in mine the USB input for the radio is in the centre console between the front seats, at the top of the little ledge and it has a flip-up cover. It is right next to the AUX input (two cable jacks).
Corbul
Jan 31, 2023 09:25 AM
Hewkins
Nov 11, 2016 01:45 AM
TBier
Sep 10, 2016 10:10 PM
Shree meher
Aug 7, 2016 09:33 AM
MassMitsu
Mar 8, 2013 03:11 PM
