Outlander III 2.4, engine filter replacement
Old Mar 31, 2016 | 07:26 PM
Bartosz Koziarek's Avatar
Default Outlander III 2.4, engine filter replacement
Hi,
Does anybody know how to remove two clips from air duct intake in order to replace engine filter ?
Old Apr 1, 2016 | 02:44 PM
Lancerguy2013's Avatar
Originally Posted by Bartosz Koziarek
Hi,
When Mitsu changed the air box design (2012 I think) it became a lot more difficult to change the Air Filter.....my 2009 Lancer was a breeze..just open the 2 silver clips and pull it apart..done.
AFAIK...you have to pop the little grommets (sp?) out of the intake and disconnect the electrical connector..Its in the manual...
The worst part is getting the air box to line up properly on the bottom after you get it apart and install the new filter...its a bitch ...at least for me... perhaps other members could chime in with a trick or technique?
I just let the Dealer do mine...2015 Outlander SE
best of luck..
Old Apr 1, 2016 | 07:34 PM
Thanks,
So you don't remove the air intake from the front ( above radiator) of the car?
Because I'm having issue with two plastic clips? Should I use some strength or use some trick?
Best,
B
demoneyz
Apr 16, 2018 05:03 PM
Nickolka
Apr 7, 2018 03:32 AM
OutlanderGT
Mar 4, 2014 04:55 PM
tims
Apr 29, 2012 12:51 PM
joeba
Aug 2, 2011 08:58 PM
