Outlander Not Reaching Optimal Gas Mileage
Old Jan 5, 2019 | 05:14 AM
SERPENTOR's Avatar
Default Outlander Not Reaching Optimal Gas Mileage
I have a 2008 Mitsubishi Outlander XLS V6 Automatic 6 Speed 4WD, I used to be able to reach 22-28 miles per gallon(In 2WD Mode) fairly easily. Now I am lucky if I reach 20 MPGs. Has anyone experienced this issue? What can I do to fix it?
Old Jan 5, 2019 | 03:49 PM
Wheeldog's Avatar
Same vehicle here and I have always gotten 20-23 mpg in 'mixed' driving - not pure city, not pure highway, mostly rural back roads but speed limit 40 mph for the most part. 20 mpg is pretty normal for this time of year where I live (CT). I believe the best I have ever done for pure highway is 26 mpg - no way I've ever seen 28 mpg.
Not sure what the issue might be for you, but here are some ideas:
- Is it running the same as it was before? Down on power, or everything just the same?
- Is the tire pressure good all around?
- Any recent work done that might have caused a problem?
- Different tires? (I think I remember you posting about replacing tires)
I'm sure you've already thought of all that, but hey - you asked.
Good luck.
Old Jan 5, 2019 | 11:51 PM
SERPENTOR's Avatar
I feel that it is running great in terms of power, just recently I replaced all the shocks, Struts, inner and outter tie rods. I did get new tires and they are very grippy, what tire pressure do you set your tires to? I am in New Jersey. I was wondering if getting a scan tool could help but there are zero warning lights on not sure if the code reader would help.
Old Jan 6, 2019 | 06:01 PM
Wheeldog's Avatar
I just run what the plate says - 32 psi all around.
I'm not sure what could cause such a drop for you. In my experience certain tires can cost you 2 mpg or so, but that's about it.
I wouldn't bother with a code reader either as it seems there aren't any codes. How about air filter - changed lately?
Old Jan 6, 2019 | 10:26 PM
SERPENTOR's Avatar
Yes I purchased a new Green Air Filter.
Old Jan 7, 2019 | 06:22 PM
15_OS's Avatar
I’m the winter around here, (North East US) they refineries use a winter blend fuel to prevent gas line freezing and such and it affects fuel mileage a little. Also, running your windshield defroster also runs your a/c compressor to help clear the windshield and that drag in the motor will also cause a drop in mileage.
cruz4mitsu
Jun 6, 2026 02:28 PM
SERPENTOR
Jul 27, 2016 01:17 AM
Larryinchicago
Sep 24, 2010 10:24 AM
benjaminws
Jul 20, 2009 09:39 PM
Silvertooth
Aug 3, 2006 10:45 PM
