Outlander TC-SST 2010 issue
Old Aug 8, 2011 | 12:44 PM
mashop's Avatar
Default Outlander TC-SST 2010 issue
Hi,
I have a UK model Outlander 2010 model with a TC-SST gearbox diesel automatic. It has 16K miles and is only 8 months old.
The problem is intermittent with the gearbox I beleive, in that sometimes when the gear changes from 3rd to 4th it feels jerky and the gear change is not smooth. it almost feels the car jumps over a small road bump when the gear change occurs. I am not paddle shifting or using the gear lever, it is in pure automatic normal mode.
I took it to the mitsubishi garage as the car is under warranty, they were unable to detect the problem simply because they only had it tested for a day. The problem does not occur all the time only occasionally. The simply returned the car to me, however I will report this to Mitsubishi UK.
Has anyone else experienced this problem or know what is wrong?
Many thanks
Old Aug 8, 2011 | 01:07 PM
Vadimus's Avatar
Originally Posted by mashop
Hi,
Many thanks
Not many people here have TC-SST.
This transmission has two clutches - for odd and even gears.
If one of them fail, you should feel the problems on all 3 gears.
If the problem is limited to 3-4 shift, I'd blame the software.
Ask dealership if they have any firmware upgrade for your transmission.
Old Aug 8, 2011 | 07:09 PM
mashop's Avatar
Vadimus,
thanks, its very odd this only happens between 3rd and 4th. I just hope its not anything mechanical i.e. the clutch etc.
Anyhow I have it booked in for the 23rd and will post back the outcome. They plan to keep it for 3 days before returing it. Hopefully they will detect the problem and do something about it!
regards
Old Sep 3, 2011 | 07:30 AM
mashop's Avatar
Gave the car to mitsubishi for 3 days. they said they performed all sorts of tests on the car but could not replicate the issue.
Like I said the problem is intermittent however when it occurs it does not seem right, it almost feels the gears are slipping between 3rd and 4th.
I am surprised they could not do a software/firmware upgrade. Also am wondering if this is something to worry about as it only happens occasionally.
morrun
Aug 18, 2015 12:42 PM
KB1Alpha
Aug 28, 2014 07:56 AM
fullgas
Jun 27, 2011 11:49 AM
rcpax
Apr 1, 2008 02:07 PM
