P1773 and abs light
Old Jan 10, 2021 | 09:32 AM
scott15's Avatar
Default P1773 and abs light
Need some help. After installing new right rear hub my 2015 outlander sport / RVR worked great. After about 200 kms the abs light came on while driving in snow. After i turn vec off and restarted the light went out drove about 150 km and it came on again. Restarted vec and light went out. Drove for about 400 km and it came back on and now stays on. also now getting code p1773. i am about 4 hrs away from dealer and warranty is up. do not want to start putting parts on unless needed. any help.
Old Jan 10, 2021 | 12:18 PM
ccernst's Avatar
https://mitsubishiforum.com/forum/mi...%20%2B%20%2460.
Sounds like your sensor is not working, or commucating.
Old Jan 10, 2021 | 02:12 PM
DibbyDibbyDJ's Avatar
You have possibly damaged the sensor when replacing the hub
Old Jan 12, 2021 | 01:16 PM
scott15's Avatar
Had it checked today. rr abs sensor problem. rockauto does not have 1 listed for 2015 rvr but does have one for 2016 outlander sport will this work?
Old Jan 12, 2021 | 02:29 PM
ccernst's Avatar
Only way I can think of to validate is to go to an oem mitsu parts page and look up oem for each....if it matches, you are good....may have to look back at 2014?
wynn003
Apr 19, 2021 03:36 PM
scott15
Feb 18, 2021 06:51 AM
bigdaddy12
Mar 20, 2017 02:52 PM
cackerma
Nov 28, 2012 12:33 PM
quixmac
Sep 2, 2012 07:46 AM
