Paint Problem
Old Sep 16, 2008 | 09:22 AM
Printerman's Avatar
Default Paint Problem
Hi:
Has anyone noticed the paint being worn away by the gas cap cover…
I have a white line forming on the right side of the cars body where the gas cap cover
meets the cars body…..
Old Sep 16, 2008 | 11:43 AM
azjake's Avatar
Default RE: Paint Problem
Nothing thats visible from the outside, but here is what I did notice. I opened the gas cap cover and the paint on the inside of the opening's right side looks a little thin. It almost looks like they used a paint brush (rather than spray) to put it on and you can see what looks like brush marks.
Old Sep 16, 2008 | 02:10 PM
Shambala's Avatar
I thought it was normal to have thinner layers of paint around the gas cap since that's an area which is usually covered by the cover. Then again it could be that some gas gets splashed around and corrodes away the paint...
Old Sep 16, 2008 | 02:47 PM
azjake's Avatar
One of the nice little features of the outtie is the lip thats underneath the opening where you put gas in to catch anyspills they may leak out from the hose when removing it.
Old Sep 16, 2008 | 03:33 PM
Printerman's Avatar
The white is showing on the outside of the car by the cover.......
Old Sep 16, 2008 | 03:36 PM
Shambala's Avatar
That little plastic lip is only functional if you have the time to ... wait around for the gas hose to clear a little bit before pulling it out of the gas tank. If you just do it at normal speed there will always be some that spills around... maybe a bigger lip would have been better.
Does anybody have the premium alloy gas cap ?
Old Sep 16, 2008 | 03:42 PM
Printerman's Avatar
THe white spot is on the car body by the flapper cover. it has nothing to do with the gas cap.....
Old Sep 16, 2008 | 07:44 PM
chenarm's Avatar
Can you send a picture?
outtie
Aug 8, 2014 08:46 PM
Gsteclipse22
Feb 27, 2006 04:24 PM
Gsteclipse22
Feb 26, 2006 06:40 PM
anko_kun
Dec 14, 2005 11:14 AM
BurntGSX
Mar 3, 2004 12:14 PM
