Put summer tires with TPMS back on.
Hello,
I've read quite a few threads on TPMS subject, but can't find one answer.
The summer tires have TPMS, my winter tires don't. I had to reset the warning all winter long. I'm going to have the dealer put back my summer tires soon (with TPMS) during scheduled maintenance (oil & rotation). They said the TPMS will have to be reprogrammed ($30).
What I don't understand, if the computer was not reprogrammed when I put my winter tires on, why does it have to be reprogrammed for the summer tires so the warning goes away?
The tires are the same, with the sensor IDs still paired with the system, I guess. Is it because of the tire rotation?
Thanks
[Update]
Just had the summer tires put on without TPMS reset. 5 minutes of driving, the warning is gone.
Thanks
[Update]
Hi
Spring of 2009
I had my summer tires put back on at the dealer, they never mentioned recalibration
or offered it. TPMS warning light went out within 15 seconds of leaving the place.
I never actually thought there would be issues. I am with you, tired of resetting display panel
Spring is getting close!! jerry
Spring of 2009
why not just have them put the tires on and decline them to be reprogrammed. If they continue to cause problems, ask them how much it would cost. Then call to a major tire shop like a firestone, goodyear, or National Tire & Battery and see if they can reprogram. What's the worst thing that can happen?
I have winter wheels without TPMS and the stock ones with the system. When I put the summer ones back on in the spring, the TPMS works fine, and I rotate the wheels every change. It usually takes a few drives for the light/warning to go away, but after that everything is fine. They may be preying on people because it does take a few drives for the warnings to stop. This is my third winter doing this. 2007 LS AWD.
Hello,
Thanks
Thanks
Is there a way to disable the warning/signal I just thought about it and I hope its not going to be going off all summer or will it not even recognize that there is no TPMS ?
