Quick Important Question on TPMS
Old 12-25-2008, 07:30 PM
ShortyRider's Avatar
Default Quick Important Question on TPMS
Hey everyone! I'm about to buy new tires for my Outie, the Yokohama AVID TRZ, anyone have them? How are they?
But the important question is that when I change the tires,
1) The TPMS is with the valve stem right, therefore, removing the stem removes the valve stem, am I correct?
2) Is there a special tool to place back the valve stem (along with TPMS) so it gets to right torque, and doesnt over torque it.
3) After everything is done, do I just need to place back the wheel, and the TPMS activate itself??
Thanks
Old 12-25-2008, 08:40 PM
dsm1990gsx's Avatar
Default RE: Quick Important Question on TPMS
Do you have the regular rubber valve stems or are they metal?
Old 12-25-2008, 09:08 PM
Well, Im not sure, because I didnt take it out and look at the TPMS stem that the Oulander has
Old 12-25-2008, 09:17 PM
mightyOUTTIE's Avatar
ya i need some info on this too thanx shorty for posting this.
Old 12-26-2008, 12:48 AM
tdford's Avatar
Our valve stems are metel, which helps you know that they have TPMS
Old 12-26-2008, 11:34 AM
dsm1990gsx's Avatar
They're two types of tpms, one is a metal valve steam w/ a nut on it and the other is on the inside mounted 180* from the valve stem.
There is not special tools to remove them but to "relearn" the sensors you'll need a special tool from the dealer.
Also if you have the tmps that is the valve steam DO NOT remove the core in the valve steam, remove the nut then you can let the air out the tire.
Old 12-26-2008, 03:18 PM
Ohh, I see. So when letting the air out from the TPMS, do not do that by removing the stem.
Im scare that the guy that are installing the tires mess up my TMPS, and I do not want to bring the tires to the dealer to install and charge me 96 bucks!
I know that there is a torquing tool thats set at 4 lb.feet to torque the valve stem in, so it doesn't over torque and damage the TMPS, just not sure if the Outlander is like that
Old 12-26-2008, 03:25 PM
dsm1990gsx's Avatar
Well who ever does the tires if they mess up the tpms they should fix it too.
newguy2007
09-27-2007 09:23 AM
claytonkobe
06-17-2007 11:07 AM
NESticle
05-01-2007 03:17 PM
DeathCabForCutie
05-21-2006 03:58 PM
g9s5t
10-12-2005 08:32 PM
Quick Reply: Quick Important Question on TPMS
