R/H position lights (front/rear) and glove box light not working
Old Nov 24, 2022 | 07:09 AM
larsfalksen's Avatar
Post R/H position lights (front/rear) and glove box light not working
Hi,
In my Outlander Phev model 2016 R/H position lights (front and rear) turning on in sec and turn off. Front lights can be use as driving light but not as position lights. There have troubleshoot everything, checking wires. One thread I saw was if glove box light bulb is not working, changing could fix the my problem - but it didn't fix it. And glove box light with new bulb didn't light either??
Do I've a ETACS issue here? Are I'm going to use at least $ 1500 to fix my problem.
Do you've other ideas to fix my problem
Hope you can help me out from $1500 :-)
Regard.
Lars
Old Nov 25, 2022 | 02:58 AM
DibbyDibbyDJ's Avatar
Did you use the bulb from mitsubishi.. The blue one?
Other bulbs do not work as the rating is different.
If so you may need to get the codes read and erased, but replacing the bulb has always worked for me
dinomight
Feb 27, 2026 12:38 AM
iihardyii
Jun 21, 2021 11:00 AM
ionicaw
Nov 30, 2019 06:18 PM
stanza75
Jun 8, 2016 12:50 AM
alopandur
Apr 27, 2009 03:40 AM
